Small problem, is this right?
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
I recently put a 4th gen rearend in my 89 camaro, and after gettting everything tightened up, I noticed that the driver's side tire sticks out about a 1/2 inch past the fender. The passenger side tire lines up perfectly with the outside of the fender. I used all of the suspension parts off of my car. The only thing 4th gen is the rearend. My car does have an UMI torque arm kit and UMI subframe connectors, but that should not make any difference I dont think. Is this 1/2 inch normal, or did i overlook something?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: Small problem, is this right?
you did remember to attach trace brace / panhard bar to body ? you did use the same springs ?????
Car: 84 Z
Engine: L69 305
Axle/Gears: 3.73 Posi
Sounds like you need to shorten the Panhard bar a bit to center the rearend up. (of course this is only possible if you have already upgraded to an adjustable one...)
Car: 87 IROC Z
Engine: 5.7 L98 TPI
Transmission: 700r4,2500 stall
Axle/Gears: G80,10 bolt 3.42's
If your car is lowered you`re for sure gonna need the adj pan hard bar to center the rear.Been researching this myself for a future install.
theshackle
Mar 5, 2017 06:37 PM
