biggest tires on gta rims?
Old Apr 12, 2009 | 01:51 AM
firechicken76's Avatar
Car: 88 Trans am GTA
Engine: 2002 Ls1
Transmission: t-56
Axle/Gears: Ford 9" 4.11 gears w/ locker
88 gta rims, what are the largest width tire that will fit on them?
i currently have 255's on them, will 275's fit?
keep it mm, instead of inches thanks.
Old Apr 12, 2009 | 09:44 AM
paul_huryk's Avatar
Car: 1984 LG4 Camaro
Engine: 350 Roller Motor
Transmission: Level 10 700R4
Axle/Gears: Strange 12 bolt 3.42
Re: biggest tires on gta rims?
255 is the widest you can safely fit...
Old Apr 12, 2009 | 10:20 AM
Stephen's Avatar
Car: 87 GTA
Not so....
I've run the BFG 295/50 on one, with zero problems. It even falls with BFGs specs, as to the recommended wheel size. And I'm not the only one, so it isn't a case of "you got lucky" either.
It is the 50 series "tall" sidewall that allows it to fit easily & safely. Were it a 40 series sidewall, then no.....A 295 wouldn't fit.
Old Apr 12, 2009 | 10:31 AM
Bratthauer's Avatar
Car: 2001 Grand Am GT/ 1987 Trans Am GTA
Engine: 3.4 V6 Ram Air/ 350 TPI
Transmission: Automatic/ Automatic
Originally Posted by Stephen
Not so....
So then would i be able to put 295/50r15 on mine or doesnt the rim size matter and does the brand of tire matter or will they all be the same?
Old Apr 12, 2009 | 10:37 AM
Stephen's Avatar
Car: 87 GTA
What size 15" wheel?
Look at Tirerack 295/50r15s to see whats available & what wheel size will fit that size tire.
For example....The 295/50r15 tire I took a quick look at, fits 8"-11". Unfortunately, I think the stock 3rd gen 15s are only 7" wide.
Old Apr 12, 2009 | 10:41 AM
Bratthauer's Avatar
they are 205/60 but they arent stock rims. the car is a 87 gta. and form wat ive been told as long as the tire is wider than the rim it will work. but if the tire is narrower it wont.
Old Apr 12, 2009 | 10:55 AM
Engine: 2002 Ls1
Transmission: t-56
have any pics of a 295 on a 16" crosslace? how about 275's? i believe you, just want to see what it looks like. might use 295's on a differant rim for the strip and a sticky 275 for street.
Old Apr 12, 2009 | 11:03 AM
Stephen's Avatar
Car: 87 GTA
The crosslace is no different (size-wise) than the 91/91 Camaro 16" wheel.
ONLY pic I have of my old Camaro is this, that kinda shows them....
Old Apr 12, 2009 | 03:14 PM
Engine: 2002 Ls1
Transmission: t-56
found some BFGoodrich Radial T/A 16 50 295 wonder how sticky they are?
Old Apr 12, 2009 | 04:18 PM
Guest
Guest
Posts: n/a
Not very. They're kind of a lousy tire honestly.
Old Apr 12, 2009 | 04:28 PM
Engine: 2002 Ls1
Transmission: t-56
that would explain the lower price
Old Apr 12, 2009 | 05:57 PM
Stephen's Avatar
Car: 87 GTA
FOUND some?
Dude...I linked to those same tires in my first post.....its not different colored text for no reason.
Its been years, but I don't recall ever being unhappy with them, on my 92.
Old Apr 13, 2009 | 12:46 AM
Engine: 2002 Ls1
Transmission: t-56
chill out, i clicked on your link Tirerack 295/50r15s and then changed the wheel to a 16, i guess i didnt click on your first link, either way, it gave me a price on them.
Old Apr 13, 2009 | 12:56 AM
Stephen's Avatar
Car: 87 GTA
In Post #3, I gave the link to the 16" version. Look before you tell someone to "chill out".
Old Apr 13, 2009 | 01:04 AM
Engine: 2002 Ls1
Transmission: t-56
Dont get a wild hair up your *** because you think i stole your thunder by saying "I" Found it, I also said i clicked on the wrong link, and then found it, not trying to take anything away from you by saying I found it, just clicked on the wrong link, thats all. I appreciate your help, but dont feel like getting into an argument over a simple mistake.
Old Apr 13, 2009 | 09:28 AM
fastcars's Avatar
Car: '92 Camaro RS
Engine: 454 Multi-port EFI Big Block
Transmission: T5-anyone have a T56 for sale?
You can get Cooper Cobra G/T's in a 295/50/16 as well. Seen them listed at Summit. Cooper suggests 8-10 inch wide rims for these tires so they should fit without a problem.
Old Apr 13, 2009 | 09:34 AM
Stephen's Avatar
Car: 87 GTA
Somebody is self-absorbed over WHO found it....
I was simply confused over how you "found" it, when the link was already provided....Whether it was by me or somebody else.
Old Apr 13, 2009 | 10:53 AM
Engine: 2002 Ls1
Transmission: t-56
i heard those are pretty good, have you ever run them?
im running toyo ra1's now, great tire, just too narrow...expensive too.
Old Apr 13, 2009 | 12:31 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
I ran the Cobra G/Ts on my car in 235/55s when I first got them. They suck ***, hard. I was afraid to drive the car in the rain. Going to a wider tire with a harder compound doesn't make any sense at all. The BFGs that were linked are a 400 A B compound. Personally, I'd feel better with a <300 AA A in a 245/50 than either the BFG mentioned or the Cooper (I'm assuming your going for handling). IIRC, the Coopers numbers are simlar to the ratings on the BFGs.
Old Apr 13, 2009 | 01:09 PM
Engine: 2002 Ls1
Transmission: t-56
do you know the compound of my ra1's?
Old Apr 13, 2009 | 01:43 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
*UTQG Treadwear 40 *UTQG Traction A *UTQG Temperature A
They are a R-compound tire, so they are designed more for track use than street use.
If I had to guess, I'd say a set of the Toyos in 255/50R16 or 275/40R17s would give you alot better traction than the 295/50R16 BFGs or Coopers from looking at the UTQG ratings. But, they won't last nearly as long as the other two. My next set of tires (summer) are going to be 300 AA A. Hoping they are better than my current BFG g-Force Sports (for a little less money).
Old Apr 13, 2009 | 08:15 PM
Engine: 2002 Ls1
Transmission: t-56
well, going to a bigger size might make up for the harder compound right? i dont really want to buy some toyo ra1 295 because, like you said they wont last long.
Old Apr 14, 2009 | 11:08 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Well, get a tire in the middle of the field. I like my BFG g-Force Sports. I'm going to a Sumitomo HRT Z III this summer to try them. I don't think you'd be happy with the performance of the 295s over even the skinny RA1. Although, you'd get alot more life from them.
Old Apr 14, 2009 | 01:00 PM
Engine: 2002 Ls1
Transmission: t-56
ive gotten over a year out of these ra1's, but yea i want something that will stick to the pavement better than my ra1's so like you said, somewhere in the middle with 295s
Old Apr 14, 2009 | 02:21 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
With the RA1s being a R-compound DOT tire, I don't think you'll get much better. But I've not driven on them, so they might not be as good as they should be. Plus, on the road, they don't shine as well as they would on the track. There is a long post on cornercarvers.com that goes into tire selection, what people ran, what they think, etc. Really long and in depth read. You might be able to find something you like on there. It's where I got the idea to try the Sumitomos.
Old Apr 16, 2009 | 07:00 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
i really like that white stripe on the blue.
anyone ever run the firestone firehawk 500's?
i cant figure why they are so cheap when they put more tread on the ground than BFGoodrich of the same size. anyone know?
i'm going to get 235 60 15 for the front and 255 60 15 for the rear. even then the rear will be an inch larger than stock diameter and if i went to 275's on the rear it would be 2 inches greater. any suggestions?
and i do like that white stripe on the blue.
Old Apr 16, 2009 | 07:07 PM
Stephen's Avatar
Car: 87 GTA
Originally Posted by tony_cogliandro
i really like that white stripe on the blue......and i do like that white stripe on the blue.
Thanks, but that always make me "cringe".....
It was actually a shade-shifter blue-to-purple paint job. The pics ALWAYS showed it as blue. In person, there was NEVER any question that it was purple....No idea why cameras always saw it as blue.
mitch_04
Members Camaros
20
Sep 20, 2021 02:24 PM
Street Lethal
Apr 30, 2019 12:14 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
demontransam89
Wheels and Tires
Dec 28, 2015 06:58 AM
BlackMagic1984
Wheels and Tires
Aug 24, 2015 06:35 AM
