manual steering owners inside
Car: 87 IROC Z28
Engine: Custom Forged 355
Axle/Gears: 9" 4:11's Detroit Locker
im gonna have to run a manual box from a g body or a s10 i hear fits, due to my turbo setup i have to get rid of the pump for now....so anyone here that has one....what did you have to change, just the box and the steering shaft also....direct bolt in .....and finally....how hard is it to drive...big differance....or not really.....i do have 245 tires in the front of the car....
any help with this would be great....thanx guys
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: manual steering owners inside
Using a 84+ S10 box is a direct swap. Remove power steering box and related hydraulic parts. Install S10 box. It's recommended that you swap over the third gen pitman arm onto the S10 box. It's slightly longer than the S10 pitman arm and will keep the same steering geometry.
Look for an S10 manual box with the 4 bolt top cover. The 3 bolt top cover is the older version and isn't as easy to swap in because of the different shaft sizes.
Manual steering boxes can only be found in S10's that came with the 2.5L 4 cylinder engine but not all 2.5L S10's have manual steering.
Car: 87 IROC Z28
sweet man.....thanx for the help.
That is a rather general question, there is allot to be considered... Ratio of the box, size and width of the tires, size of the steering wheel, ride height, stiffness of springs, pitman arm ratio, modified or stock spindles... The list goes on, my point here is that you cant use someone else experience as a point of reference for yourself, your friend could say "I have 13" tires up front and its a piece of cake" then your 160LB self can seem to parallel park with 9" tires while pulling up next your 260lb gorilla friend.
You can make a manual box go lock to lock it one turn and be extremely sensitive but its going to be nearly impossible to turn under 25mph...
I have the stock IROC wheels and tires up front 245/50/16 with the mannual s10 4bolt box talked about above post . the front suspention on my car is no sway bar , 70/30 struts . It is not that bad to steer when moving , from a stop , parking etc it can be alittle bit of a pain but not to where I whould take it out and go back to p/s . I'm about 150 lbs just my opinion .
Car: 91 Formula
Engine: L98 350 TPI
Transmission: TH700R4
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
Well I don't know how much help I can be but I just got my manual box in and it's really not that bad turning the wheel from a stop, but my car is grossly lightened. So turning effort is great reduced. I have 245-50-16's on GTA wheels. From just regular driving steering effort isn't much different than stock, just alittle tighter.
there is alot of flex on the frame mount of the box and this doesnt help steering
imo id only put one in a drag car
see if you can get a hydro boost system outa a astro van
Car: 86 Monte Carlo
Engine: Blown 489
Transmission: TH400
Axle/Gears: 9" 370s
im running a manual box in my 86 monte, with a blown 489 stroker. easy to turn and tok 15 minutes to put in.
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
