weird problem. 15x10 fitment
Old May 1, 2009 | 09:04 PM
92camarors5spd's Avatar
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
Axle/Gears: strange 12 bolt 3.73's
ok so i just got my 15x10 w/ 5.5 back spacing. mounted my 28x12.50-15 et streets. bolted them up and minus having to clearance the calipers i have 1-2inches of clearance from the inner fender well. and looks like the outer fender is going to make contact with the tire.
i was under the impression that i would have to remove metal off the inner fender not have to do something about the outer fender... tomorrow i will get pics when i lower the car down on the ground and see what your opinions are on clearancing the outer fender, maybe just rolling the frender lip?
Old May 1, 2009 | 09:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: weird problem. 15x10 fitment
Your Strange 12 bolt may be the width of a forth gen diff.
Old May 1, 2009 | 09:28 PM
Car: 1992 camaro rs
Engine: 346 ls1
Transmission: t56
hmm good point. but i believe it is the same length as stock because i cant run 4th gen rims without spacers.
Old May 1, 2009 | 10:11 PM
AC's Avatar
AC
Car: Used to drive a camaro
I'd think that 12.5 wide tire on top of a 2" taller than stock OD would be need a inner fender roll for sure. I've never dealt wtih wider than a 9.5 rim or 275 tire so Stephen and the rest of the crue woudl have to cofirm / negate the idea.
Falcon50
Aug 22, 2020 03:26 PM
RS Reaper
Oct 17, 2018 07:52 PM
C409
Dec 17, 2016 09:35 PM
HoosierinWA
Oct 7, 2015 10:15 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
