V6 swaybar size
Car: 91' Firebird
Engine: 3.1 LH0 V6
Transmission: Auto 700R4
Axle/Gears: 3.23 limited slip
V6 swaybar size
Hi, im bought new endlinks (both are broken) for my front swaybar and decided to do the swaybar bushings and add a wonder bar. I found some bushings on summit but I'm not 100% sure they're right. They say for 34mm, is that what the V6 came stock with?
http://store.summitracing.com/partde...4907958+400008+
And am I going to see a huge difference, since basicly the car has no front swaybar now and i'm adding a wonder bar with poly bushings?
Thanks.
Thanks.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: V6 swaybar size
Your last sentence is confusing, but here goes.
The wonderbar will make the steering more precise.
You do have a sway bar now, its most likely not a 34mm bar. You need to get a set of calipers and measure it.
New bushings for the bar are a good idea, but probably wont make a difference that you will notice.
Car: 91' Firebird
Engine: 3.1 LH0 V6
Re: V6 swaybar size
Really? What size ya think it is?
And I say I basicly have no swaybar since both endlinks are broken off so it's not hooked to either control arm.
Car: 86 Trans Am
Re: V6 swaybar size
its probably a 32 at most.
if both end links are busted, you will notice quite a difference when you hook them back up.
Car: 91' Firebird
Engine: 3.1 LH0 V6
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Pac J
May 17, 2020 10:44 AM
