Clunky Front End, What To Replace?
Old May 18, 2009 | 12:28 PM
Ninety-One's Avatar
Car: 91 LT1 RS 89 IROC-Z 350 TPI
Engine: LT1 // 350 TPI
Transmission: WC T5 // 700R4
Axle/Gears: BW 9 Bolt 3.27 //BW 9 Bolt 2.77
My car has 190XXX and I know stuff in the front end needs replacing. My question is, what should I replace? I'm kind of on a budget, and when I move my steering wheel side to side theres slop and it clunks, I tried greasing all the ball joints but it didnt help. Also my dash vibrates above 70 on the freeway. tires are balanced, and all shocks and struts are new.
Old May 18, 2009 | 02:39 PM
Aviator857's Avatar
Car: 1989 Firebird
Engine: 5.7 LS1
Re: Clunky Front End, What To Replace?
My first suggestion is the idler arm. But I would really suggest all the linkages as this is a safety issue as well as a drivability issue.
2x inner tire rod ends
2x outer tire rod ends
1x drag/centerlink
1x idlerarm.
Check the steering gear, if there is play in it it can be adjusted with the screw on top of the box do a search There should be items turn up.
Ball joints should also be checked and possibly replaced.
I'm going to get flamed for this but you can get all at autozone for pretty cheap 30 ish for the tierods 50ish for the center link, 30ish for the idler arm. Its all life time waranty items so just swap them out as they wear. Or go with the rebuild kit from sphon if you want good parts.
Then get a front end alignment.
Old May 18, 2009 | 08:02 PM
oil pan 4's Avatar
Car: 89 Firebird
Control arm bushings are likely shot too.
4 things fixed my front end clunk (its never just one thing)
1 Strut tower bushings
2 control arm bushings
3 loose strut to spindle bolt
4 front end alignment
Old May 19, 2009 | 06:32 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
I used this kit from Spohn, with very good results. You can chase down parts at various Auto parts stores and save a few bucks, but is it worth it.
Old Oct 30, 2009 | 12:32 PM
Ninety-One's Avatar
Okay, thanks guys. Took me awhile to get the money together, but I bought The Steering rebuild kit from Spohn, and a complete set of poly bushings for the whole car and ball joints too. I'll let you all know how it turns out, I'm gonna be doing the overhall this weekend. Thanks for the help.
Old Oct 30, 2009 | 12:44 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
I'd also check wheel bearings and ball joints while your under there.
Old Oct 30, 2009 | 02:27 PM
Stephen's Avatar
Car: 87 GTA
I discovered that clunk, clunk coming from my rear end, was a thin disc brake pad. Despite still having pad on it, it was loose between the caliper & disc.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
bellez77
Sep 5, 2015 08:39 PM
mizz0313
Aug 12, 2015 06:45 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
