CHANGING THE REAR
Old May 29, 2009 | 06:36 PM
rojas1826's Avatar
Car: 86 iroc-z
Engine: 305 tpi
Transmission: 700r-4
Axle/Gears: 2.73 lsd
CHANGING THE REAR
Today i was looking around online for a rear end swap for my camaro i want to know what good this will do : 82-92 Camaro/Firebird 3.27/posi 9-bolt PBR disc brake rearend. Has about 90k miles and works great. The 9-bolt rearends were a rare option on these cars and are much stronger than the factory 10-bolts. Also, this rearend has the later style PBR rear brakes which are larger and much more reliable than the earlier style. 9-bolt rearends only came with the PBR brake one year so this is a very hard rearend to find. Comes complete with the rotors, calipers, and WS6 rear sway bar. How hard will this swap be and what will i need?
Old May 29, 2009 | 06:48 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: CHANGING THE REAR
It's pretty easy, also, it's been covered a million times already, so try a search!
Old May 29, 2009 | 07:02 PM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Went with a 89 9-bolt when I swapped rear a few years back and the only problems was the brake line fittings were different. SAE & Metric if I recall. Also make sure you get the parking brake cables & proportioning valve for the 9-bolt.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
BlackTopKing
Aug 19, 2015 12:13 PM
kyleb24
Aug 15, 2015 08:24 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
