Best road course set-up???
Old May 31, 2009 | 05:22 PM
86camaro#4794's Avatar
What would be the best road course set-up for a third-gen? I have a couple frineds in it and I drag race mine. I want to get another one to set up for road course. Don't know much about raod racing so idk where to start.
Old May 31, 2009 | 09:31 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: Best road course set-up???
Well i may not be much help, but its better than nothing.
I would do all tubular suspension with GOOD rod ends.
-LCAs
-reloc. brackets
-PHB
-Torque Arm, the new trans mount adjustable kind
-K member
-A arms
Then perhaps good brakes?
-check out Ed Miller's site flynbye performance, he'll set you up
Then Driveline
-alumminum driveshaft
-obviously good motor trans and rear, i think a manual would be best for road race
Probably the most important is tires springs and shocks
-eibach pro kit
-koni's
-and some awesome super sticky tires
Safety
-cage and 5 points
-----remember i'm no pro and this is what i think would be a good setup. the list is in no order of importance either
Old Jun 1, 2009 | 10:56 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
If you don't know much, get out to a track and start driving the car and talking to experienced drivers. Even with all the mods in the world, an unexperienced driver will not know how to drive a car fast. Then, do some research- are you going to try to compete or are you just wanting a good handling car to play with and have fun driving on a track? If you are going to compete, you need to pick a class and modify the car according to the class rules.
Old Jun 1, 2009 | 12:09 PM
UMI Sales's Avatar
Hello
Look into a set of sway bars and shocks and springs, and then SFC's and an adjustable pan hard bar! That will give you a solid base to build on! Below is a link to show you what all we have to offer!
http://www.umiperformance.com/82-92fbody
If you have any other questions feel free to ask and I will be glad to help!
Brad
Linson
Oct 24, 2025 02:00 PM
RS Reaper
Oct 17, 2018 07:52 PM
Lbibb
May 5, 2016 12:00 AM
lewandom
Oct 1, 2015 08:15 AM
Zell1luk
Sep 29, 2015 10:36 AM
