wheel spacing question
Old Jun 11, 2009 | 10:59 AM
Chezoom's Avatar
Car: 91 RS Vert, 87 SC T-Top
Engine: LO3, LG4
Transmission: 700r4's
Axle/Gears: 2.73, not sure yet
i got 4 rear wheels (forumla wheels) that im going to paint black and put on my car, all 4 are for the back so what do i need to put 2 rears on the front?
Old Jun 11, 2009 | 11:15 AM
Stephen's Avatar
Car: 87 GTA
Re: wheel spacing question
Very common to to put fronts on the back, but not rears on the front. You'd need spacers to do that.
Stock, the rear wheels are 16mm offset, the fronts are 0mm offset. So to get the rears to equal the fronts, you'd need 16mm (.63") spacers. 1/2 might be a hair too small, 3/4 would be a little more than really needed to make them fit the same, but would still be a very good choice.
Judging by the length of the stock lugs, you might hafta get bolt on ones (like from Skulte.com) instead of just slip on spacers.
Old Jun 11, 2009 | 11:26 AM
Chezoom's Avatar
Engine: LO3, LG4
could i just get some bolts that are 3/4" put them on and call it a day?
Old Jun 11, 2009 | 11:35 AM
Stephen's Avatar
Car: 87 GTA
Longer studs, yes. Just "bolts", no.
The wheel studs are pressed in, Not exactly an easy at-home-job, to press the old ones out & press new ones in.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
kah992
Aug 19, 2015 02:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Fronzizzle
Aug 9, 2015 01:15 PM
