K members
Old Jun 11, 2009 | 09:36 PM
ericjon262's Avatar
Car: 85 2M6, 87 'Bird 88 'burb
Engine: LX9, LG4, L05
Transmission: F23, 700r4, 700R4
Axle/Gears: 3.63, 2.73, 4.10
K members
I've seen the BMR and the Spohn tubular K members, are there any other options?
also, what K member are you running if other than stock?
pros and cons?
Thanks-
Eric
Old Jun 12, 2009 | 01:37 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
Re: K members
PA Racing makes one too. Heard some complaints about the fitment of the spohn piece, a search will tell you all about it.
Old Jun 12, 2009 | 09:06 AM
BMR Sales's Avatar
Former Sponsor
Re: K members
pros and cons?
Thanks-
Eric
Our third gen k member will save you 30lbs and adding our a arms will drop another 20lbs. The k member is made from 1 5/8" x .120 dom steel tubing with 3/16" mounting plates. It can withstand daily driver or any type of racing that you do. It is a direct bolt in with no fabrication required. We offer two styles of a arms. One with spring pockets for use with an oem style spring and the other with no spring pocket for use with our coil over conversion set up. If you have any questions please give me a call.
http://www.bmrfabrication.com/index.htm
Attached Thumbnails K members-km007hsmall.jpg   K members-aa007k-small.jpg   K members-aa008-small.jpg
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
