Mysterious Clunk and shaking
Old Jun 7, 2009 | 01:18 PM
crusinman2002's Avatar
Car: 1989 Camaro RS
Engine: 305 for now
Axle/Gears: stupid open diff. 2.73 i think
hi all, got a question, maybe someone has had the same thing happen and knows the fix. When i turn the wheel all the way while i'm moving, doesn't matter which direction, I hear a Loud Clunk from the right front side. When i hear the sound, i cant feel anything in the wheel or in the car. What should i check? wheel bearings, ball joints, are going to be checked, but is there anything else that could cause this?
also, there is a slight shake in the car up to 60mph, and above 60mph the shake gets worse, so i don't drive more than 60mph right now. I'm hoping that the problems are tied together. The shake is in the steering wheel just a bit, but mainly in the car. its bad enough that i can't really pinpoint which side or anything its coming from. could the ball joints or wheel bearings cause this?
also, are the wheel bearings in the rotors? cause when i was looking at new rotors from autozone, they were listed as rotors / wheel bearings
any help will be appreciated
Old Jun 8, 2009 | 06:32 AM
jrz28's Avatar
Car: 1984 Berlinetta
Engine: 305 Carb
Re: Mysterious Clunk and shaking
Check your sway bar end links, the bolts that connect the sway bar to the lower control arm, this is what happened to mine a few months back.
Old Jun 8, 2009 | 07:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Originally Posted by crusinman2002
also, there is a slight shake in the car up to 60mph, and above 60mph the shake gets worse...
Alignment? Wheel balance?
The inner and outer bearings and seal are usually purchased separately.
JamesC
Old Jun 8, 2009 | 08:37 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
It sounds like a balljoint to me, but while you're there, check your tie rod ends, idler arm, and control arm bushings as well. I would also check the nut under the dust cap that holds the wheel bearings in place. If that is loose, it can allow the bearings to slide in and out on the spindle.
As for the vibration at speed, tires and/or alignment are usually the culprits as mentioned by JamesC. Less likely, but also possible are the sway bar-to-frame bushings and play in the steering gear.
As to your question about the wheel bearings, the hub is cast into the center of the rotor so it is all 1 piece instead of your typical 2 piece hub/rotor design. You should replace the wheel bearings any time you replace the rotors, and repack the bearings with fresh grease any time you have the brake pads replaced.
Old Jun 8, 2009 | 11:46 AM
Car: 1989 Camaro RS
Engine: 305 for now
will check the tie rod ends too. would i be better off just replacing all the bushings up front? going to replace the ball joints, and the wheel bearings first though, and see if that fixes it. the car pulls slightly to the right, but when sitting on level ground the left (drivers) side sits a little bit lower up front. pretty sure that is just the ball joints.
how bad are the ball joints to replace? last set i did was on a chevy cavalier, and they were really a pain. had to drill out three 1/2inch rivets on each side just to pull the ball joints, and the bolt the new ones back in. are the camaro's easier or worse? from looking at the pictures of replacements it looks like they will be easier than that, but i don't know if the pics are accurate and haven't pulled a wheel/tire yet to go and look.
thanks, for the info
Old Jun 8, 2009 | 12:30 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
I just did mine a month or 2 ago. First time ever doing balljoints and it took me a couple hours for each. Getting them lined up perfectly and staying that way when taking them out and putting the new ones in was the most frustrating part of it. I bought a cheapie Harbor Freight balljoint press. It's basically a massive C-clamp and its not an easy job. Putting the new balljoints in the bottom of my freezer overnight helped along with taking my Dremel and using a sanding drum to clean out the control arm holes for the balljoints.
Old Jun 12, 2009 | 01:17 PM
Camaroz2892's Avatar
Car: 92 Camaro Z28
I dont have any shaking but i get the same popping noise whenver i turn my wheel all the way in one direction. This just started after i replaced all and i mean all my suspension components so hopefully i can also find an answer.
F-body driver
Mar 6, 2023 11:44 AM
Gordonr1973
Sep 29, 2015 11:59 AM
luvofjah
Sep 26, 2015 08:28 PM
ynk1121
Sep 12, 2015 12:27 AM
Ragtop Man
Sep 12, 2015 12:23 AM
