Steering Joint & rag joint eliminator
Old Jun 15, 2009 | 04:17 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Has anyone done both the Steering U Joint & rag joint eliminator?
Old Jun 15, 2009 | 08:49 PM
screeminchicken's Avatar
Re: Steering Joint & rag joint eliminator
Dont get the rag joint eleminator . They cause steering binding and wear out soon
Old Jun 16, 2009 | 09:04 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Can use Flaming River and/or Astro Van parts to make one. There are several pictures of the results posted here on TGO.
RBob.
Old Jun 16, 2009 | 09:25 AM
FueledSoul's Avatar
any links you could post?
Old Jun 16, 2009 | 11:19 AM
Guest
Guest
Posts: n/a
https://www.thirdgen.org/forums/susp...ing-shaft.html
Old Jun 21, 2009 | 10:54 PM
FueledSoul's Avatar
Thanks for the link, not looking to spend all that money on a shaft.
i looked more into a rag joint eliminator i think all just replace the one i have with a new one. I havent looked into it much but i see these all the time in autoparts stores and are farly cheap like from dorman link:
https://www.dormanproducts.com/cgi-b...84360&item_no=
how do these hold up in a heavy connering force/load?
i would also like to replace the upper portion of the shaft. would some type u-joint work?
Old Jun 22, 2009 | 11:02 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Originally Posted by FueledSoul
Thanks for the link,...
In that link, the OP used a 1"DD to 3/4"DD u-joint to replace the upper joint in the shaft.
Ed1LE
Sep 30, 2018 09:14 AM
loud91rs
Oct 5, 2015 10:05 PM
RS Reaper
Sep 27, 2015 07:04 PM
Night rider327
Sep 25, 2015 04:19 AM
