camber caster plate ground control or hot part
Old Jun 25, 2009 | 01:07 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
i want to have some more room to play with along with the weight jacks i'm ordering so i'm going to be getting a set of camber/caster plates.
The hot part piece looks very nice and is a pretty straight forward design.
on the other hand i really dont understand just looking at the picture how the ground control system works. I realize it retains the stock upper strut mount, but since my car is going to end up in street modified at any events i go to keeping it legal isnt a concern.
are there any benefits to the ground control system?
both links
http://www.hotpart.com/shop/index.ph...uct_detail&p=8
http://www.ground-control-store.com/...p/II=134/CA=86
Old Jun 25, 2009 | 04:38 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: camber caster plate ground control or hot part
the ground control one installs in the stock strut mount, replacing the rubber mount. It can be rotated to get more adjustment out of the mount. I think its legal is stock suspension classes.
The hotpart one is obviously a complete new piece. I Just ordered a set of the hotpart ones with my weightjacks. I used to have the hotpart mounts, the first design when it was just a flat plate and spacers. It was a nice piece. I sold them to a member here a couple years ago.
I know that with the Hotpart mount that i used to have, you could position the strut anywhere inside the opening in the tower. The only way to get more adjustment would be cutting the opening in the strut tower larger
Old Jun 26, 2009 | 08:39 AM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
k i've given up on any future aspiration of running in street prepared. Modified it is. Hot part strut mount ordered, weight jacks getting ordered this afternoon
Old Jul 4, 2009 | 01:57 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
I never even knew Ground Control offered strut mounts for our cars. Doesn't matter though because I went with J&M mounts (2nd design) anyway. I've been using them for about a year now and I have nothing but good things to say. I use my car for daily driver duty and for a lot of autocross events.
Old Jul 4, 2009 | 12:46 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
ya i ordered the J&M piece, was a bit of a no brainer, looking forward to seeing how much the caster adjustment makes a difference in the way the car handles on a tight autocross course.
Old Jul 6, 2009 | 05:25 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
I love the hotpart.com camber plates. They are used almost exclusively over on the F-body road race forum on thirdgens. Here is how you adjust them with the car on the ground....
Old Jul 6, 2009 | 06:51 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
thanks for the picture. my hot part mounts just showed up in the mail today! so excited, cant wait for the rest of the front end parts
eightsixseven
Dec 16, 2024 01:50 PM
customblackbird
Aug 15, 2021 10:16 PM
midge54
Jan 29, 2017 07:00 PM
1nastygta
Aug 8, 2015 07:38 PM
johanlindgren
Wheels and Tires
Aug 6, 2015 03:32 PM
