Gettin' it together
Old Jul 5, 2009 | 09:27 PM
SixSeriesCSi's Avatar
Car: 89 Formula, 85 Trans AM & 91 Bird
Engine: 5.0 CARB, 5.7L TPI & 3.1L V6
Transmission: T-5/700R4/700R4
Axle/Gears: 9 Bolt & 10 Bolt X2
Gettin' it together
I went out and bought a set of Blisten Shocks from Autozone. I paired them up with a set of Sportline Eibach Springs. Seems to be that everyone here is asking what's good and what works, I guess it might be a little too late for me to ask, since I already bought the parts. I plan to pair this together with my Edelbrock Strut Tower Brace. Anyone have any Experience/Knowledge regarding these parts?
Old Jul 16, 2009 | 03:40 PM
Re: Gettin' it together
Someone should delete this if no one is going to answer...
Old Jul 17, 2009 | 03:05 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Haven't done the strut tower brace yet - but I love my Bilsteins and Eibachs! Although, I got the Eibach Pro Kit instead of the Sportlines. Since you'll have it all apart, I'd reccomend new sway bar bushings, end link bushings, tie rod ends and ball joints if it's not been done yet. I spent a whole day on mine, and replaced all these with the new springs and struts, and did poly bushings all around, and the difference was night and day!
Old Jul 26, 2009 | 02:51 PM
I replaced the Sway Bar End Links with a red set from Energy Suspension, How much should I tighten them??? (The book said 14lbs, the instructions said till they plump up) I also want to know what size sway bar I have, since I want to replace the sway bar bushings too. What is the Eibach Pro Kit? I heard there are a couple different Blisten Shocks for our cars, Anyone familiar??? Thanks to those who have helped me by answering my pesky questions.
Old Jul 26, 2009 | 03:12 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
2 ways to figure out the sway bar diameter. 1st an easiest buy a micrometer. 2nd way if you have a good set of over sized wrenches slide the wrench over till you find the right size.
Old Jul 26, 2009 | 06:52 PM
Thanks for the info. Any more Help???
Old Jul 29, 2009 | 04:33 PM
Is the Pan-hard bar, removed while the car is jacked up or on the ground???
Old Jul 29, 2009 | 05:09 PM
1988-305-tbi's Avatar
i have removed it both ways, probably want to have it up on jack stands, but with the rear tires still touching the ground, to keep it from moving around to much
Old Jul 29, 2009 | 05:23 PM
Car: 1992 RS
Engine: Carbed 350
Originally Posted by SixSeriesCSi
What is the Eibach Pro Kit.
The Pro Kit is only a 1 inch drop - I believe the Sportlines are a 2inch drop.
Old Aug 2, 2009 | 08:28 PM
Which is stiffer the Pro Kit, or the Sportlines??? Has anyone installed an Edelbrock Strut Tower Brace???
Old Aug 2, 2009 | 08:30 PM
Sway Bar End links, Any Idea on the torque specs???Previous post up above...
Old Feb 17, 2011 | 01:01 PM
I will be adding a UMI Chromoly Performance Pan Hard Bar. With Double Adjustable Ends and Rota Joints!
Still looking for the Torque Specs for my Sway Bar Endlinks?
Intrested to hear if anyone has run the Blisten Test/Heavy Duty?
Spring Rates for Stock, Sportlines, and Pro Kit?
Thank You. Have Good Day!
Old Feb 17, 2011 | 02:51 PM
Car: 1992 RS
Engine: Carbed 350
Don't know about spring rates - sorry. Wanted to let you know I did install an Edelbrock STB, I could tell a difference with it. I'm carbed, and the Edelbrock was a decent 3-point piece for a carbed motor, plus I got it used and cheap.
That panhard bar you chose ought to be a nice piece - overkill for me though - too fancy and too many $$$. I'm running a Edelbrock adj panhard bar - only adjusts on one end, not sure why some bars adjust on both (seems like overkill to me) - but I've had no issues at all with my el-cheapo Edelbrock. I'm strictly street though - no racing here, just fun in the city, maybe the higher priced fancy schmancy bars are beneficial at the strip - all I know is my wallet enjoyed the savings, andf my bar works great on the street.
Old Mar 14, 2011 | 01:55 PM
I found that Blisten Test and Blisten Heavy Duty Shocks/Struts are the same thing (Same Part Number).
Just Purchased...
UMI Performance Cast/Camber Plates
UMI Performance Lower Control Arms out of Chromoly with Double Adjustable Ends/Rota Joints. (Plus the Hardware Kit)
Shipping out on Wednesday!
Stay Tuned!!!
Old Jun 12, 2011 | 04:38 PM
Added a UMI Chromoly 22mm Rear Sway Bar...
Old Aug 14, 2011 | 01:07 AM
Added a set of UMI Chromoly Double Adjustable Lower Control Arms with Rota Joints. UMI Cast and Camber Plates.
Old Aug 14, 2011 | 06:50 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
[QUOTE=SixSeriesCSi;4854489]Just Purchased...UMI Performance Cast/Camber Plates.../QUOTE]
Good idea. The above will be more effective in combination with the STB than the OE mount would be.
JamesC
Old Aug 14, 2011 | 11:12 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Pro Kit: 714 lb/in linear front 1 inch lower front
109/177 lb/in progressive rear 1 inch lower rear
Sportline: 700 lb/in linear front 1.6 inch lower front
80/137 lb/in progressive rear 1.3 inch lower rear
Old Aug 14, 2011 | 02:17 PM
My only complaint in regards to the Edelbrock Strut Tower Brace is the mounting points to the actual strut towers. I don't like the idea of having to drill the necessary holes. I prefer the the UMI Strut Tower Brace Design that incorporates the brace mounting points with the bolts used for the actual strut towers. It's adjustable too.
Old Aug 14, 2011 | 02:28 PM
JamesC's Avatar
The following has info/pics:
https://www.thirdgen.org/forums/susp...-3-pt-stb.html
JamesC
Old Aug 15, 2011 | 06:57 PM
Here is a shot of the Adjustable Rota-Joint from the Chromoly Pan Hard Bar, Enjoy...
Attached Thumbnails Gettin' it together-adjustable-rota-joint-pan
Old Aug 15, 2011 | 09:22 PM
Here is a shot of the Passangers Side Rear Shock. You can see a glipse of the UMI Chromoly Rear Lower Control Arm with those Wonderful Adjustable Rota Joints, Enjoy...
Attached Thumbnails Gettin' it together-rear-pasenger-side-shock
Old Aug 16, 2011 | 08:53 AM
Here is a shot of the Passenger side Cast and Camber Plate, Enjoy...
Attached Thumbnails Gettin' it together-passenger-side-cast-camber
Old Aug 18, 2011 | 10:35 PM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
Where did you get the spring rate info. I couldnt find this at all when I was doing my spring research and choose someone else since I couldnt find this info?
Old Aug 19, 2011 | 02:39 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
If this is a street car send that bar back and use a V6 bar from a 4th gen.
Only use the fat rear bar if your ditching the front bar and going drag racing or are going to run a road course.
I run the little bar on the street and its sooo much better, no hoping around corners when you hit a bump..
Old Sep 8, 2011 | 11:31 AM
TTOP350 Could you enlighten me with more information on the size of your Rear Sway Bar.
I wish UMI would include New U Bolts/Washers/Nuts and Mounting Brackets for their Rear Sway Bar's. I had to order them seprately ($65.00)
Old Sep 16, 2011 | 10:30 AM
Here it is, UMI 22MM Chromoly Rear Sway Bar.
Enjoy...
Attached Thumbnails Gettin' it together-22mm-umi-sway-bar
Old Oct 6, 2011 | 06:57 PM
I've decided to go with Black Suspension Components for the Front. Just added a UMI Front Steering Brace. Waiting for a Group Buy on those Wonderful New K-Members...
Old Dec 22, 2011 | 12:33 AM
I wish this thread was a bit more coordinated.
None the Less, Here is a shot of the UMI Front Steering Brace.
Enjoy...
Old Dec 22, 2011 | 12:37 AM
Damn, forgot the photo...
Old Dec 22, 2011 | 08:14 AM
UMI Sales's Avatar
Hey SixSeriesCSi.
Thanks for keeping this UMI thread going. Your car should be working pretty well with all these goodies.
We are working hard to finalize the new k-member. It's going to be pretty sweet.
ramey
Old Dec 22, 2011 | 10:02 AM
Hey Ramey I noticed the Front Steering Brace I returned in the Scratch and Dent Sale...
Old Dec 22, 2011 | 10:04 AM
UMI Sales's Avatar
Was it scratched and dented?
Old Dec 22, 2011 | 10:48 AM
The first one shipped appeared to have some Defects in the Powder Coating. I think you guys do an Excellent job in Powder Coating your Products, because of that I didn't want to have a piece that didn't look as good as the others. (I believe I posted a reply to my first Return/Exchange Experience with UMI)
Old Feb 13, 2012 | 11:36 AM
Just purchased a set of UMI Lower Control Arm Relocation Brackets. They are Bolt-In. I don't plan to throw them on just yet, though...
My 9 Bolt is leaking from the Pinion Bearing, Gear Oil is thick messy stuff.
Old Feb 16, 2012 | 11:24 PM
Here is a shot of the UMI Lower Control Arm Relocation Brackets, Enjoy...
Old Feb 16, 2012 | 11:26 PM
Ugh forgot the Photo Again, Sorry...
Attached Thumbnails Gettin' it together-umi-lower-control-arm   Gettin' it together-umi-lower-control-arm   Gettin' it together-umi-lower-control-arm
Old Feb 17, 2012 | 07:17 AM
UMI Sales's Avatar
Awesome. Can't wait to see them on your car!
Thanks for choosing UMI for all your traction needs.
ramey
Old Apr 12, 2012 | 11:13 AM
I sold my Edelbrock Three Point Strut Tower Brace to one of the ThirdGen.Org members...
Old Apr 12, 2012 | 08:20 PM
jchaussee's Avatar
Car: 85 Z28
Engine: 327
So I assume you are building a high HP, hi torque street machine?
Old Sep 26, 2012 | 11:21 PM
That's the plan....
Old Dec 2, 2012 | 03:49 PM
  #42
Christmas came early...
Here is a shot of the UMI Performance Strut Tower Brace, Enjoy!!!
Old Apr 24, 2015 | 03:01 AM
  #43
I sold my Lower Control Arm Relocation Brackets to one of the ThirdGen.Org members...
The new design from UMI allows for more adjustability of the Lower Control Arm.
Old Apr 25, 2015 | 08:29 AM
  #44
CharcoalBird's Avatar
Car: 1991 Firebird
Engine: 3.1L V6
If your sticking with your eibachs and don't plan on running something like weight jacks to adjust your ride height...not sure you really need MORE adjustability as your going to set it once and be done with it.
Old Apr 28, 2015 | 06:11 PM
  #45
Zach/90\irocZ's Avatar
Car: 88 Formula, 90 Iroc RIP, 92 RS Sold
Engine: 305 to 350
Axle/Gears: 10 Bolt
what you get is not adjustability but abilitiy to run different springs to get to handle the way you want it, ajusting the ride height is a added bonus,
weight jacks are over kill for the street but then again a 300+ hp sbc or lsx swap is also and whats any fun if it isnt overkill but we really dont need it lol
but eibach springs will satisfy majority of people on the forum for street use i never was happy with sportlines and or dropzone/intrax or what ever new name they have now
Old Apr 28, 2015 | 10:25 PM
  #46
It would be quite a shame to throw all these components together and have a regular shock and spring combo... The plan is to eventually switch over to Weight Jacks and different Shocks with more adjustability. Initially, I'd wanted to go with coil overs but the front of our cars are not set up to handle that amount of weight without additional bracing.
Tonyy_z
Aug 12, 2015 07:20 AM
CD MaroMan 91
Dec 10, 2001 12:24 PM
Warrior
Nov 9, 2001 10:49 PM
mark406
Jan 24, 2001 09:24 PM
ihateallmustangs
Dec 7, 2000 09:38 PM
