Need Help with finding a pressure line for my power steering
Old Jul 23, 2009 | 08:03 AM
Demonic87z's Avatar
Car: 87 Iroc Z28
Engine: 5.7 Carb
Transmission: TH350, B&M shift kit, Huges 3000 sc
Axle/Gears: 3:23 Posi
Thanks EVERYONE in advance for any help on this.
I am building a show car, 87 Iroc, 90% complete. I have a Keyway power steering pump from a 72 Camaro (keyway have MUCH nicer pulleys than press fit) and I have the original power steering unit from the 87 camaro. The 87 pressure line does not fit the 72 pump, Does anyone make a pressure line for this configuration? Does anyone know what size the fitting on the 72 pump and the 87 gear box are for the pressure line? OR is there an adapter I can use on the pump? ANY help would be GREAT, Thanks Again!!!
Old Jul 23, 2009 | 08:44 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Need Help with finding a pressure line for my power steering
The pressure fitting assembly from your '87 pump will thread right into a '72 pump. I've put '91 pressure fittings into stock GM '67 pumps.
Just keep the same spring and intermediate valve together with the pressure fitting. And in the same sequence and orientation. As you unthread the pressure fitting the spring will push that and the other piece out. So keep them in order. Note that the spring pressure is light, only a few pounds. But it is enough to pop the parts onto the floor if not careful.
RBob.
Old Jul 24, 2009 | 08:44 AM
Demonic87z's Avatar
Car: 87 Iroc Z28
Engine: 5.7 Carb
Thanks ALOT Rob!!! It worked great, I never knew you could switch them.
Awsome...
Old Jul 24, 2009 | 11:17 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
After opening some of these pumps up on the bench I was amazed that they are basically the same. From '67 through '91 (and probably '92). The pump vanes are thinner in the newer pumps. And there is some minor machining differences. And of course the shaft has been changed.
But other then that, they are identical. Even the same casting number for the body.
And some place along the way a magnet was added to the pump casting. Just stuck on at a low point.
RBob.
Old Aug 15, 2009 | 09:02 AM
Power Z's Avatar
Hi Guys
I'm looking for a keyway ps pump for my 83 Z28. Does this mean I could use a ps pump from an early 70's 305 and it would bolt right on?
Old Aug 15, 2009 | 04:26 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You may need to change the tin around the pump. But otherwise the guts will be the same.
RBob.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
wayshegoes
Aug 17, 2015 12:00 PM
Kaweh
Aug 9, 2015 02:54 PM
