Frame/Chassis Limits?
Old Jul 25, 2009 | 12:48 AM
Lundy's Avatar
Car: 91 Chevy 1500 Ext.Cab,
Engine: 350 V8,
Transmission: 700R4 4spd. auto,
Axle/Gears: 3:90 posi,
My Dad and I are thinking about turning an 89 RS into a drag car and were wondering what the hp. and torque limits are for the Frame/Chassis.
Any comments are helpful.
Old Jul 25, 2009 | 01:08 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: Frame/Chassis Limits?
You need Sub Frame Connectors no matter what your power limits are. I ran my car to 12.0 with just SFC. I also had aftermarket LCA and panhard bar and some home made LCA relocation brackets. Other than that, front and rear suspension was basically stock. It was making roughly 500 HP at the time.
When I hit 12.0, I had a 6 point roll bar installed. Back then it was required at 11.99. Now it's required at 11.49.
The third gen rear suspension while using aftermarket components can run easily into the 8's. I back halved mine a couple of years ago because I wanted to run a much bigger tire than what can be stuffed under the fenders.
Ed1LE
Sep 30, 2018 09:14 AM
jrdturbo
Mar 31, 2016 02:58 PM
racereese
Oct 3, 2015 03:46 PM
drumstixer
Sep 29, 2015 03:02 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
