Steering wheel off 45 degrees
Old Aug 8, 2009 | 08:36 PM
Chuck's Avatar
My 88 IROC-Z drives straight as an arrow.
But... when it does, the spokes on the
steering wheel are off about 45 degrees from
where they should be.
Any suggestions to fix this?
Old Aug 8, 2009 | 08:44 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Steering wheel off 45 degrees
with the wheel in that position, where the car drives straight, in what direction in the pitman arm facing? If its not point straight back, you alignment was done improperly and needs to be re-adjusted. Or there could be some damage to the car or steering parts that are causing this issue with alignment.
If the pitman does point straight back, and the wheels turn just as far in both directions, the steering wheel is on wrong. Don't do this until you are sure nothing is wrong as described in my first paragraph.
Old Aug 8, 2009 | 08:45 PM
yoshirocks702's Avatar
Car: 1984 Chevy Camaro Z28
Engine: L69 5.0L H.O.
Transmission: T-5 5 Speed
Axle/Gears: 3.73:1 Limited Slip Posi
try unbolting the steering wheel with the wheels straight and then re-position the steering wheel as close to straight as you can, and bolt it back on. to take off the steering wheel you need to pop the horn cover off, and disconnect the horn wire, then there should be i think 8 torx bolts holding the steering wheel on. hope this helps
Old Aug 8, 2009 | 09:03 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
thats not the way to go about doing this. Make sure the issue is not with the actual steering linkages first. However it is possible that the wheel was rotated so the driver could see a certain gauge better, its was most likely caused by an incompetent tech doing an alignment without centering the wheel first, or a combination of that and bent steering linkage
Old Aug 11, 2009 | 10:10 AM
LTPMarine's Avatar
sounds to me like your alignment is off. u don't want to screw around with the steering tho so unless u really know what ur doing..I'd take it to the dealership.
Old Aug 11, 2009 | 11:54 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
The center mark on my steering column shaft is off by about 10-20* clockwise, but my wheels are straight, is this a sign of needing an alignment?
Old Aug 11, 2009 | 12:02 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
to fix have it re-aligned...they will straighten steering wheel...pretty easy fix....but that is if steering wheel is on correctly....
they will adjust both front tire rod ends to correct wheel straightness.....in on one side and out on another side....
morrow
Jan 13, 2024 12:29 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
wild1
Aug 27, 2015 09:01 AM
Keiffer76
Car Audio
Aug 9, 2015 11:37 PM
mustangman65_79
Aug 9, 2015 03:00 AM
