Which Sway Bar Bushings?
Old Aug 10, 2009 | 04:16 PM
Jr. Mechanic's Avatar
Car: 1983 Camaro Z28
I have my rear end pulled out to replace the gas tank. While I'm at it, I figured I would clean everything up. I need a set of sway bar bushings, Prothane sells universal sets, I just need to know which one as I forgot to measure and the old bushings are at my shop.
The car is an 83 Z28 with the G80 rear end RPO. Here's a link to the bushings:
http://www.jegs.com/p/Prothane/Proth...62160/10002/-1
Old Aug 10, 2009 | 06:05 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Which Sway Bar Bushings?
Your best bet is to measure the sway bar itself.
JamesC
Old Aug 10, 2009 | 06:15 PM
As I said the car along with everything is at my shop or else I would. I was hoping to get them ordered tonight.
Old Aug 10, 2009 | 06:38 PM
JamesC's Avatar
If you car's rear is OE, then you should have an F41 suspension and a 21 mm rear bar. Check the following link:
https://www.thirdgen.org/forums/faq-...-sway-bar.html
JamesC
Old Aug 10, 2009 | 06:44 PM
LB9Iroc87's Avatar
Car: 1987 Iroc-Z28
Axle/Gears: G92 3.23, G80, J65 disc
Energy Suspension or Prothane are your best bets, do u plan on gettin polyurethane or rubber? I'm not putting my word on it but i think the Z's came with 19 or 20mm rear sway bars.
Old Aug 10, 2009 | 07:23 PM
JamesC
Thanks! I still don't know which style I need though, and at this point I might as well wait until tomorrow.
Ed1LE
Sep 30, 2018 09:14 AM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
darwinprice
17
Oct 11, 2015 11:51 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
