symptoms of bad u joints
Car: 1988 Flame Red Trans am GTA
Engine: Forged 355 4 Bolt, FIRST TPI
Axle/Gears: ls1 torsen 3.42 gear
hey everyone its me again.... this september i am going to be getting the bmr torque arm and their relocation bracket.. they make excellent products by the way.... so i will have to take my driveshaft out anyways..... but here is my problem, everytime i put the transmisson in any gear i hear this tiny little clunk or screech noise and when it down shifts i hear it also... im pretty sure its either my u joints or the torque arm bushing or maybe even the torque arm itself.. because they never have been replaced... i think the way gm mounted these things on the driveshaft is not the best idea they came up with.. the transmisson shifts and works perfectly... i have a stock aluminum driveshaft that came in my 1988 trans am gta.. i was wondering what kind of u joint do i need to buy for it... i would like to replace both of them while im doing my torque arm upgrade... any help would be appreciated...
also i have a stock rubber mount for my transmission.... would upgrading to a poly mount be wise... what is the benefit of a poly mount over the stock rubber type.... thanks again..
Re: symptoms of bad u joints
The stock TA mounts to the trans tailshaft, not the driveshaft
The TA mount can be at fault but usually the issue is with the mounting bolts coming loose or the crossmember mount breaking (very common)
A bad U joint will make a clunking sound when you shift gears and also make clunking noises when you shift under light throttle and coasting
A good way to check is to put the car in neutral (chock the wheels) and twist the DS. If you can feel any play between the DS and rearend yoke then the U joint is bad
oops... i meant to say tailshaft sorry about that.. but thanks man what you described is exactly whats happening it makes a popping sound under light throttle and coasting and whenever i put it in any gear..... i just dont like the idea of the torque arm mounted on the tailshaft plus its weak and it flexes... so im just going to get bmrs torque arm and relocation bracket.... i will do that test about the driveshaft in the morning... but im pretty sure thats what it is...
A good way to check is to put the car in neutral (chock the wheels) and twist the DS. If you can feel any play between the DS and rearend yoke then the U joint is bad[/quote]
hey pocket where can i get the best u joints for my car.... i have a stock aluminum driveshaft and i have a 700r4.. i looked and there are different types and im unsure of which ones to get..
I havent had any problem with letting the shop pick whatever
Just say I need a new U joint on my DS and they should take care of it for <$50
http://www.bmrfabrication.com/F3.htm
BumpaD82
Feb 26, 2016 02:57 PM
IROCZDAVE (88-L98)
Nov 19, 2015 07:03 AM
bubbaz28
Sep 18, 2015 02:09 PM
MikkoV
Sep 9, 2015 04:25 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
