swapped to pa coilovers car now shakes at 45
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Hey just swapped to my pa racing coil overs finally. got them all in and all and now when i get going around 45 or so the car like whobbles as if i had a wheel coming off. I just got the car aligned and camber checked and it stil does it. car has no sway bar is a power steering setup no pump though. also has 90/10 struts and 3inch skinnies up front. not sure what the issue could be im thinking maybe losse tie rod ends or a bad steering column??????? anyone have any ideas?
Guest
Posts: n/a
Re: swapped to pa coilovers car now shakes at 45
lets rule out the obvious- It has to be something that was either newly installed or something taken apart and not put back together correctly when you did the coilover install.
Startfrom basics, what was on there prior to this install - are for example the skinnies new? or did they drive fine on it prior to the coilover install ...etc.
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Absolutely nothing was changed othe than the springs. Everything stayed the same. All I did for the swap was unbolt the top of the strut and that was it
1992 Trans Am
Aug 8, 2015 08:16 PM
