Looking for new/rebuilt steering column
Old Sep 9, 2009 | 01:02 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Anybody know where I can get a new or rebuilt steering column for my 91 RS? All I can find online are used columns.
Old Sep 9, 2009 | 02:54 PM
ssean92's Avatar
Car: sold
Re: Looking for new/rebuilt steering column
there is a thread around here the will show you how to rebuild the column
https://www.thirdgen.org/steeringcolumn
Old Sep 9, 2009 | 07:55 PM
Engine: 350 TBI
Thanks Sean, but my actual column is bad, not just loose. I was down at Hurlburt field and one morning the car wouldn't start. I thought the ignition cylinder had gone bad, but I took it to a shop recommended by somebody we used to work with. The found the cylinder was fine but various parts in the column had come apart. They put it back together enough for the ignition to function, but said the column needed replaced ASAP. I would have gotten more specifics, but I was out of town and needed to get going. Also tend to trust them because they new I was out of town so its not like they would be getting the business. Somebody else previously mentioned my whole column was bad as well.
I definitely want to find a new or rebuilt column.
Old Sep 10, 2009 | 02:17 AM
Scorpner's Avatar
Car: 85 SC, 86 Berlinetta
Engine: V6, V8
Transmission: 700r4, 700r4
I've come across some decent ones at a junkyard like a pick-n-pull. Easy to pull. Two bolts under the dash, three at the firewall and one on the shaft IIRC. Sometimes the key is under a seat or hidden somewhere nearby. make sure it has the same options and VATS requirements unless you can bypass that.
Old Sep 10, 2009 | 06:04 AM
ssean92's Avatar
Car: sold
It is going to be hard to find a NEW one but you might beable to find a good used one. I will look around for you Chris.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
