General Suspension Questions
Old Sep 16, 2009 | 01:56 AM
totalchaos's Avatar
So after driving my car home I realized it was in need of some suspension work. So I am going to start with the obvious shocks, struts, and springs. I was leaning towards these (http://www.kybshocksonline.com/Prod_...35773&pid=1329) while drawing a blank on springs. The only thing I could find were the lowering springs which I am not quite ready for yet. Any suggestions?? And is there anything else I should check for while under there that these cars maybe notorious for (1991 RS)???
Old Sep 16, 2009 | 03:23 AM
Camarslow's Avatar
Car: 1984 Z28
Engine: none
Transmission: none
Re: General Suspension Questions
Moog makes good replacement suspension and steering pieces, and they have reproduction factory springs for camaros.
As for what else you should check, check the condition of all your rubber parts, balljoints, and also check and see if the steering system needs service as well.
Old Sep 16, 2009 | 07:10 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you haven't already, you might check the stickies at the top of the page. Chances are with a car that's galloping toward 20 years old, the front end needs a rebuild: ball joints, tie rods, center link, idler arm, and bushings--as well as the parts you mention.
JamesC
Old Sep 18, 2009 | 08:14 AM
Bungle's Avatar
Car: 1991 Camaro Z/28 Convertible
Engine: LB9 305
Transmission: A4
Axle/Gears: Stock
Does anyone make a rebuild or front end service kit for these cars? As I live outside the US i really need a kit of parts that is guaranteed to work and fit etc.
Old Sep 18, 2009 | 09:31 AM
JamesC's Avatar
Sure.
http://www.spohn.net/shop/1982-1992-...sion-Steering/
JamesC
Old Sep 18, 2009 | 10:22 AM
1Aauto's Avatar
Former Sponsor
We offer this steering suspension link kit that will make the steering nice and tight again for you.
Front Suspension Steering Kit
Old Sep 19, 2009 | 03:02 PM
Firechicken355's Avatar
Car: 1989 Firebird
Engine: Slightly modified 355
Transmission: 5-speed
I recently bought some Moog rear springs for my 1989 Firebird. I talked to the Tech Dept at Moog. They told me all they make for the rear of third gen cars is a variable rate spring. I bought a pair and installed them. They ride decent and handled ok. I had a serious case of wheel hop, which the springs and new KYB shocks took care of. I only had the Moogs in for a week or so and have since installed a set of four Sumitt Racing 1" lowering springs. Nothing against the Moog's I just wanted matched parts. By the way , my stock springs had a body height of 26" (guess they had sagged over time). The Summit lowering springs raised it over an inch. They tell me they will settle (we will see). If you are going with KYB's buy the adjustable shocks/struts. Just for what it is worth, Eibach recommended Tokico to me for their 1" lowering springs.
lt1z350
Aug 28, 2015 05:57 AM
cam-mike
Aug 24, 2015 07:23 AM
redmaroz
Aug 16, 2015 11:40 PM
