something seems amiss
Car: 87 TA
Engine: 305 tpi
Transmission: auto
For the past week i have been noticing a clunk coming from the rear, went and investigated and found my lakewood adj. panhard bar to be the culprit. Seems the threads have disappeared, anyone know where they went?
Suggestions on how to fix this? Can I just get a threaded rod end for this?
KeithO
KeithO
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: something seems amiss
it was probably loose, and the movement wore the teeth off. Provided the threads in the tube are ok, you should be able to just replace the rod end.
