Couple of SFC questions
Old Oct 24, 2009 | 09:10 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
First off I have a set of UMI sfc's I am going to install on my 88 vert.
I know the car has to have the suspension loaded when installing the connectors. But, here is what I'm curious about.
I have the car disasembled right now,almost completely.I still need to put the rear end back under it to install the connectors though.
First question:
While being completely apart do I have enough weight to properly mount the sfc's? Reason I ask is that I am currently undercoating the bottom side. I did a test fit to mask off the weld area from the undercoating. The passenger side front will need shimmed to meet the frame as it sits right now.
Second question:
Did you weld the rear section where it bolts to the lower control arm bracket? I assumed I would but then I thought I had better ask others opinions first.
Old Oct 26, 2009 | 08:39 AM
UMI Sales's Avatar
Re: Couple of SFC questions
Hello
I would highly suggest just reinstalling the rear end! And then installing the SFC's so there would not be any chassis binding issues. And then I would make sure the hardware goes through the mounts (were the lower control arm mounts and then weld around the front and top and sides. If you have any other questions feel free to ask and I will be more than glad to help.
Brad
Old Oct 26, 2009 | 08:09 PM
wvabreeze's Avatar
Thanks for the reply Brad. Just wasn't sure if the engine and tranny being out would affect anything.
Old Oct 27, 2009 | 08:47 AM
UMI Sales's Avatar
Hello
I would just wait until all the weight is back in the vehicle to eliminate any type of chassis binding issues. If you have any other questions feel free to ask and I will be more than glad to help.
Brad
chazman
Aug 28, 2018 03:25 PM
Cleotiz
Jan 6, 2018 08:56 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
