Building a decent suspension?
Old Oct 25, 2009 | 11:29 AM
willy825's Avatar
I Have a 91' Camaro RS with 90,000 miles. I'm not exactly looking for the ultimate suspension. More or less I would like to know what is completely necessary for a Camaro's suspension. I am going to have a little bit of power behind the wheels and don't want to have a ton of parasitic power loss or a twisted frame. Thanks in advance.
Old Oct 26, 2009 | 09:36 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Building a decent suspension?
Are you looking to drag race the car, street drive it, or are you wanting to improve the handling of the car? (or a combination haha)?
Old Oct 26, 2009 | 02:01 PM
89_RS's Avatar
Car: 2003 F-150
Engine: 4.6L Modular V8
Transmission: 4R70W
Axle/Gears: Ford 8.8"/3.55 LSD
Sub-Frame Connectors (SFC's), strut-tower brace (STB), and the Wonderbar are a great start no matter what you do. While they aren't suspension components per se, they do help out alot when you start doing other mods. They really stiffen up the chassis.
If you want a nicer suspension, just look at the non-adjustable poly-bushing items that BMR, UMI, Spohn and the like have to offer. They are relativley cheap and much better than stock.
If you want something that will allow for tuning of the suspension for either Autocross or Drag racing, start looking at the adjustible version of the part as well as rod-ends or pivot joints for the part. This will allow you to dial in your setup and reduce bind. These are more expensive, but depending on what you do can be a great return on the investment. Here's bind explained: http://www.elephantracing.com/techtopic/binding.htm
Hope this helps
Old Oct 26, 2009 | 09:48 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Take a look through this thread. It should help you with the basics.
J-money
Jan 4, 2019 09:45 AM
Jorlain
Oct 8, 2015 01:57 AM
SG91camaro
Sep 5, 2015 10:27 PM
tgp1990
Sep 4, 2015 06:24 AM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
