Stripped my spindle threads
Car: 89 GTA
Engine: 6.0L Procharged
Axle/Gears: 4.10
When I was removing the nut a piece of the cotter pin got jammed up in the threads and f'd up all the threads on my 1LE spindle.
The factory threads are 3/4"-20. I was thinking of rethreading it to the next size down, which would be a M18-1.5 and putting a M18 slotted nut on the spindle.
Anyone else have suggestions?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Stripped my spindle threads
what threads exactly? to my knowledge, there are no threads on the spindle, only holes for the dust shield, or in you application the caliper bracket. Almost sounds to me like your talking about the lower balljoint, in that case, just replace the balljoint
Car: 86 Trans Am
ahhh, missed that one, silly me.
hmmm, how bad are the threads? could you just run a die down the threads and clean them up?
If its beyond that, i dont see why you couldn't re-thread them, but to do it right the threaded part would need to be ground down to the exact diameter for the new threads and be round. Not sure if you could just "wing it".
Car: 89 GTA
Axle/Gears: 4.10
The threads are pretty bad from the cotter pin outwards, but they aren't bad where the nut actually goes when it is tight. I'm looking for a 3/4"-20 die to just clean it up, but it is not a common size. 3/4"-16 is standard fine pitch so our spindles are even a finer pitch than normal.
Car: 86 Trans Am
how sure are you that the threads are not metric? i have never heard of 3/4-20, nor can i find one.
Car: 89 GTA
Axle/Gears: 4.10
100% sure, I spent about 6 hours looking up spindle nuts. I bought a stock spindle nut at NAPA and it showed the thread size on the computer.
Car: 86 Trans Am
http://buy1.snapon.com/catalog/item....&group_ID=2425
i found one! it does exsist
Linson
Sep 21, 2015 01:08 PM
rb85TA
26
Sep 14, 2015 10:29 PM
