Which Subframe connectors?
Car: 1988 IROC Camaro
Transmission: 700R
I need advice on which subframe connectors to purchase and which ones to avoid. I am new to the 3rd gen camaro world and there is much more selection that I am used to
Investigating, it seems SummitRacing sells connectors from as low as $99 up to $250. http://www.summitracing.com/parts/CEE-3046/
Spohn connectors run at $199
http://www.spohn.net/shop/1982-1992-...me-Connectors/
I will be welding them to the frame (even if they are bolt-on style). So what is the real difference? Or is it just brand name vs generic? Can I get a recommendation of what to look for and what to avoid?
Re: Which Subframe connectors?
I went with the Spohn tube type when they first came out over the boxed type. Fit is really tight and the car is better now then it left the show room.
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
I went with this company below.. They mainly do convertibles, however, most of their parts are for all f-bodies.. These are the 2 piece connectors, instead of the 3 piece which IMO is not necessary...
http://www.top-downsolutions.com/pro...21c68cf08192a6
They work great....
Adrian
They work great....
Adrian
Hello,
We offer a nice set that is very popular- www.umiperformance.com/2400 they can also be purchased through Summit Racing which you posted a link too.
I have never used the Competition Engineering ones but I have heard they require modification to install them? Someone else may be able confirm that.
If you have any questions please ask. Thank you!
Ryan
Ryan
http://www.bmrfabrication.com/F3-chassis.htm
Car: 1987 IROC-Z
Engine: 406 on N20 w/ EFI
Transmission: P.B. 700R4
Axle/Gears: 12 bolt w/ 3.91
i have nothing against UMI, BMR, or Spohn..... however the chassis shop i took my car to went with a S&W racecars subframe kit. lots of points of connection, weded and bolted. driveshaft loop included.. requires the use of thier S&W tq. arm too, so be ware of that. i love my setup now..
for photos and info.. check my post below at the link :
https://www.thirdgen.org/forums/susp...rame-into.html
Car: 1982 Z28, 1983 Z28
Engine: 5.7L 530hp, 5.7L 430hp
Transmission: TH350, 700R4
Axle/Gears: Ford 9", 10 Bolt 3.23
I ended up with a square tube set of bolt/weld on no floor mod connectors from Hotchkis. I definatly felt the difference in handling right away, with no regrets about my purchase. Seems the rest of my stuff is currently UMI though.
TMZIrocZ350
Oct 7, 2015 12:09 PM
tmork454
Sep 29, 2015 06:33 PM
