Who's put some miles on their BMR k-member?
Old Dec 8, 2009 | 11:25 AM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
I'm interested in a BMR k-member for my LSx swap, but 99% of what I read about on here is for the spohn k-member.
Anybody had a BMR for a while that they care to comment on? did you zip-tie your brake line or did you come up with a better method? How low is the k-member compared to the oil pan?
Old Dec 14, 2009 | 11:14 AM
Jim85IROC's Avatar
Re: Who's put some miles on their BMR k-member?
Apparently, nobody.
Old Dec 15, 2009 | 09:05 AM
C Murda's Avatar
Car: 91 Z
Engine: Somethin Nice!!
subscribing and BUMP for ya
Old Dec 17, 2009 | 12:34 PM
BMR Sales's Avatar
Former Sponsor
We have hundreds of the k members out on the road. The k member was designed around the 98-02 4th gen ls motor and pan. We have had no failures of this k member. If you have any questions please give me a call.
Attached Thumbnails Who's put some miles on their BMR k-member?-km008hsmall.jpg
Old Dec 22, 2009 | 09:50 PM
whitedevilTA's Avatar
Car: 1986 Trans am
Engine: 5.3 LM7
Transmission: T56 6 speed
Axle/Gears: Dana 44 w/ 3.55's
Just curious, do you know if a 5.3 truck pan will clear your LSx swap K-member?
And to the OP, I have been using BMR parts for a while now. Quality, fit, and finish are awesome, and I'll be getting thier K-member and torque arm soon as well. Good luck!
Old Dec 23, 2009 | 03:43 PM
BMR Sales's Avatar
Former Sponsor
Our k member was designed around the 98-02 ls f body pan.
Old Jan 17, 2010 | 12:19 AM
littletimmy9's Avatar
i have seen pics of your k members with power rack and pinions from Appleton power rack and pinion but all the k members i have found on hawks and other places they dont have the the monting plate on them like the on i found on camaro tech the ones i have found have a pair of bars out front with to holes in each with the rack from a 4th gen camaro work on that kmember
Old Jan 17, 2010 | 08:45 PM
1987earthquake's Avatar
Car: 1987 Camaro Z28
Engine: 5.3L
Axle/Gears: 3.42LSD
Subscribing. Looking into this k-member as well when I upgrade my 5.3 to a 408. can stock a-arms bolt into this k-member or are the tubular a-arms required?
Old Jan 17, 2010 | 10:40 PM
profootbrake2's Avatar
Car: 92 Camaro Z28
Engine: ZZ4 TPI
I have had my BMR K-Member for 4 years now and I have no problems with the parts at all. I did zip tie the brake line on the bottom bar. On my zz4 I have about 1 inch of clearance between the oil pan and K-member
Old Jan 18, 2010 | 10:03 AM
BMR Sales's Avatar
Former Sponsor
Hello, the 4th gen rack is too wide for the 3rd gen. We do offer a k member that has the manual rack tabs on it.
Old Jan 18, 2010 | 10:07 AM
BMR Sales's Avatar
Former Sponsor
Hello, you will need to up grade to our a arms if you use our k member. However our tubular a arms will bolt on to a factory k member. Hope that answers your question.
Old Jan 18, 2010 | 10:55 AM
the picture i saw on this link http://www.camarotech.com/steering.html was a bmr fbody 82-92 ls1/ls2/ls6/ls7 conversion k memeber it has a appleton power rack and pinion the kmember has a drace in the center of it where the rack mounts i have looked on your website and at other places and have not found the same brace on them is this some thing i will have to add or do yall make one please get back to me thanks
Old Jan 18, 2010 | 12:05 PM
87tpi350,6spd's Avatar
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
From what I remember That is an old design and is discontinued.
Old Jan 18, 2010 | 12:14 PM
ok i want a power rack do you know of any racks that are power and will fit on this type of kmember or do you know another type product that will give me what i want with the feel of rack and pinion
Old Jan 18, 2010 | 04:05 PM
Car: 87 Trans am
Engine: 350tpi
Transmission: 6spd
Axle/Gears: 4.10
Not Sure if what you want is out there. I belive that there is no racks that will work with the spindals and still give you a good turning radius. I think somebody makes drop spindles with shorter steering arms to alow you to use a rack but I'm not sure. I would recamend doing a lot more research before you decide on a rack and pinnion setup. I heard most of them are recamended for drag use only. Anyhow if you want more info on that I recomend starting you're own thread or doing a search. as this is getting off topic pretty quick.
Old Jan 20, 2010 | 07:05 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
those appleton racks don't work very well at all. There are a few board members that have used them with very poor results. I researched it before I went with my manual setup. From what I remember everybody that had them said they were junk and got rid of them. If you do a search on the power rack subject you will find that certain year ford t bird racks have the right throw distance for a third gen so you would just need to make brackets to hold the rack. If your looking for a bolt on only powersteering rack your not going to find one. I wound up with a flaminging river pinto rack, PA racing k member and racecraft drop spindles with shorter arms for the rack. My car won't be done till spring but so far from pushing it around the shop with a motor and trans in it steering effort isn't too bad.
jbd1969
Aug 17, 2015 07:06 PM
GVMV
Aug 16, 2015 08:01 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
NBrehm
Aug 5, 2015 07:57 PM
