LCA Mounting Brackets?
Old Dec 13, 2009 | 03:23 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Has anyone ever heard of Lower Control Arm mounting brackets, that bolt/weld to the uni-body frame where the LCA'S attach too? Its to replace/reinforce the existing mounting locations. I was told by a guy whose going to weld my Sub-frames in that I should get them, or even fabracate them. I'm not talking about the LCA brackets that mount to the axle.
Old Dec 13, 2009 | 03:41 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: LCA Mounting Brackets?
never heard of them, but many subframe connectors sandwich to the LCA mount with the lca bolt, so if you dont have SFC's, get them, and it will also accomplish you idea of the LCA mount reinforcement.
AS far as the mount needing extra support, unless its rotted off, it doesn need it. The guy is probably think about torque box reinforcement that common on mustangs. The majority of the axle torque is on the torque arm.
Old Dec 13, 2009 | 07:33 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
maybe he means LCA relocation brackets.
Old Dec 13, 2009 | 07:35 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the other guy may have been, but the OP seems to be talking about the chassis side, so who knows
Old Dec 14, 2009 | 09:09 AM
UMI Sales's Avatar
Hello
No! If you read he is talking about the chassis side. And the only way is to reinforce the mounting locations on the chassis is to look into SFC because they have the reinforcement for the control arms and also support the whole chassis as well. Below is a link to show you what I am explaining.
http://www.umiperformance.com/catalo...roducts_id=127
If you have any other questions feel free to ask and I will be more than glad to help!
Brad
Old Dec 14, 2009 | 12:34 PM
Car: 1988 IROC-Z28
I guess I should have said its where the upper part of the LCA'S attach to the unibody/frame. I already have aftermarket lca's,torque arm, lca relocation brackets, and subframe connectors.
Old Dec 14, 2009 | 12:53 PM
Gumby's Avatar
Car: 86-FireBird
Engine: -MPFI
Axle/Gears: 3:42
Still can't see it in my head but anyone with a welder can help ya.
You can get small heavy plates of metal at any hardware store.
Though from what your saying, sounds like anyone with a welder n simple tools could do what ya need. paint or coat fancy for looks.
Old Dec 14, 2009 | 07:06 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
so which SFC do you have?
the way to reinforce this area you are talking about has already been covered in my earlier post, and still, i dont find it necessary.
Old Dec 14, 2009 | 08:08 PM
Car: 1988 IROC-Z28
Sorry I did see your post, I have Comp. Engineering frame connectors. And I'll take your word for it, if its not nesassary.
Thanks!!!
Old Dec 14, 2009 | 08:13 PM
Car: 1988 IROC-Z28
Since where the subject of sub frame connectors, I find when I put my ROC up on jack stands using the subs for the support. I find that if I put them up at max. height all but the passenger front side will sit level. I have to use a taller jack stand to balance it out. Does this mean my frame is bent. When the car is on all 4 tires it does not appear to sag. And the doors close well also.
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCZDAVE (88-L98)
Sep 2, 2015 08:49 AM
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
