85 z-28 chasis with 8pt Cage
Car: 1986 IROC-Z
Engine: 8100 Vortec (496ci)
Transmission: 4L80E (4spd auto)
Axle/Gears: 9" 40 Spline Detriot Locker 4.90
Whats an Z-28 rolling chasis with an 8pt cage installed worth?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 85 z-28 chasis with 8pt Cage
whatever somebody will pay for it.
depends on the quality of the install and the shape\completeness of the roller.
pics?
pics?
Car: 1986 IROC-Z
well i was looking to buy an 85 z 28 with a cowl hood and a ton of engine parts and an uninstalled 8pt cage for 1100, and take the cowl hood off and try to resell it completed for like 1500, im getting out of the military and need something to do for a week or two
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Is it an 8 point cage or an 8 point roll bar? Does it have a halo bar and A-pillar bars? If so then it's a cage. If not then it's just a 6 point roll bar with driveshaft tunnel braces for 2 more points.
Buying someone else's uncompleted project might be a good deal but can also be more headaches than it's worth. Typically a roller is worth far less than a turnkey car and a roller is never worth what's been put into it.
Car: 1986 IROC-Z
i think the project was never started lol but its roll cage i believe like mine
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
http://www.jegs.com/i/Jegster/550/94...oductId=749658 8 point 82-92 camaro/firebird buck seventy
Car: 87 IROC L98
My first cage was a Jegs. Although it fit fine, it isn't as nice a fit as an S&W cage.
Cost of a cage is nothing. Cost to install is expensive. To have someone install your cage, estimate $100-$150 per point. Prices will vary depending on how much needs to be done.
[MN] S&W 8 point rollcage
FueledSoul
Sep 30, 2015 09:18 PM
tmork454
Sep 29, 2015 06:33 PM
