Removing K member
Old Jan 11, 2010 | 09:13 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Removing K member
Is there any way to remove the K member without pulling the engine? I'd like to take mine out and clean it up/paint it, but the way I have the car in my garage there's no room to use a cherry picker in front of it. And the rear end is out of the car too so there's no easy way to move it right now..
Old Jan 11, 2010 | 11:27 AM
TZFBird's Avatar
Car: 1988 Firebird, 2000 GTP
Engine: 327
Axle/Gears: 9" posi, 4.11
Re: Removing K member
I used 2x4s screwed together and laid them across the fenders. Otherwise they make ones out of steel for doing FWD vehicles. If you use 2x4s it takes 3 at minimum(2 makes a scarry crackling sound). Laminate them together with screws and stand them vertically( III ). It held the engine/trans up for 3 days until I was finished.
The more you use, the more the weight will be distributed to prevent denting of the fender. I used three and had no problem. If you cut them shorter I suppose you could go across the strut towers. Just be extremely carefull and watch everything at all times. I had to brace the wood up because it was trying to slide down the fender towards the front. Car can be rebuilt, your head after being smashed by an engine falling 2 feet cannot however.
This is what I did to change the rear main, except I left the K-member together and ran chains down through the springs so I pretty much just dropped the assembled front suspension from the body.
I know it sounds pretty *******, but desperation to drive in the spring conquers all.
Old Jan 11, 2010 | 12:15 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Isn't that the truth. Only problem is, every time I take off one thing to fix or clean up, I find another thing that I really should do too!
Do you think the 2x4's would still work with the transmission out of the car?
Old Jan 11, 2010 | 12:44 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
How about a chain block?
Old Jan 11, 2010 | 01:05 PM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Finished ceiling above the car.. I wouldn't care about cutting a hole in the ceiling to attach a block to the trusses but I don't know how I'd get to that area without standing on the hood!
I wonder if I could use a cherry picker from the side just to hold the engine up instead. I've got all sorts of room on the passenger side.
Old Jan 11, 2010 | 01:32 PM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
you shouldn't have a problem doing it from the side.
Old Jan 11, 2010 | 06:32 PM
drperformance's Avatar
Car: 1987 firebird
Engine: 1995 lt1 383
Transmission: 4l60e
Axle/Gears: moser 9" with 3.70
I used a cherry picker from the side to lift the motor enough to pull the oil pan last winter. It can be done.
Old Jan 28, 2010 | 11:50 AM
G-reg's Avatar
Car: 90 Camaro
Engine: 350 tpi
Transmission: t56
Axle/Gears: 4.10
Just thought I'd update this thread..
The harbor freight folding engine hoist - not quite long enough to get directly above the engine from the side. Needed another 5 inches or so to get directly over the center. I might have been able to gain another 2 or 3 inches if I would have taken the fender off first.
however, with everything taken off the front down to the radiator support I had plenty of room to go in from the front
Old Jan 28, 2010 | 12:37 PM
TZFBird's Avatar
Engine: 327
Got to it to late... you're probably already done.
IROCZDAVE (88-L98)
Sep 2, 2015 08:43 AM
Night rider327
Sep 2, 2015 04:18 AM
Night rider327
Sep 2, 2015 04:17 AM
Armored91Camaro
Aug 25, 2015 12:01 PM
3rdgenparts
Aug 8, 2015 07:09 PM
