need your advice on SFC
Car: 84 Z28,03 GSXR1000,07 RMZ 250
Engine: H.O. L69
Transmission: 5spd
Axle/Gears: 3.73 possie
i did a search and couldnt find what im looking for .. the next upgrade for me is SFC , what im looking for is to get a set that i would bolt in .. but will likely weld wheni can get a chance .. the main thing im looking for is a set that doesnt require any cutting of the floor .. and clears the stock exhaust..
if you have any pics i would appreciate it ..
thanks
thanks
Engine: H.O. L69
Transmission: 5spd
Re: need your advice on SFC
thanks
thanks
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
All kinds of stuff in archives. Try a search, they sometimes work.
Mine were custom made, and welded in. Maybe a bit heavy.
They are NICE.
They are NICE.
Engine: H.O. L69
Transmission: 5spd
i did a search and couldnt find what i was looking for.. thats the fuirst thing i do when looking for info ... i want ones that i can buy and install... just dont want to have to modify the floor at all and i will likely weld in..
Hello
I am not sure of any manufactures that offer a bolt on for a third gent. But I just wanted to leave you know that UMI Performance offers a weld on version of a SFC. They mount tight against the floor and come with replacement hardware for the rear control arm. Below is a link to show you what all we have to offer!
http://www.umiperformance.com/catalo...cvacobhr7cs7f6
If you have any other questions feel free to ask!
Brad
Brad
Hello, i wanted to give you another option. We do offer frame connectors for your car but they are weld in units. We have two different versions, SFC008 is designed for cars with full length headers and exhaust systems that run inside the frame rails. SFC009 is designed for cars equipped with the OE manifolds or shorty headers with OE exhaust or OE type exhaust that runs on the passenger side, outboard the subframe. We reinforce the rear control arm mounts with HD 3/16" plate and use rectangular tubing to join three areas, the rocker pinch welds, rear control arm boxes and front subframes. Here is a link to our site. Please give me a call if you have any questions or would like to order a set.
http://www.bmrfabrication.com/F3-chassis.htm
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
S&W racecars and Alston (can get through topdown solutions) offer bolt-in SFCs. Don't know how they did not pop up in your search. Search specifically for these, will find more info and pictures, also check out S&W's web site, and also check TDS's. There is drilling required for both sets, but no cutting. Don't believe there are any sets that use all existing holes.
Axle/Gears: 3.45, 3.27, 3.27
The Alston SFC's I sell fit the bill too. They are designed to be bolted in, but can be welded in later or instead of bolting to the car.
http://www.top-downsolutions.com/pro...products_id=90
Lon Salgren
Lon Salgren
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
HoosierinWA
Oct 7, 2015 10:15 AM
