These stiff enough?
Old Feb 10, 2010 | 07:58 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Transmission: Built 700r4
Axle/Gears: 3.08 non-posi
These stiff enough?
I'm thinking about buying a 2 sets of these to replace my current springs.
http://www.summitracing.com/parts/MOG-5610/
The moog spring has a rate of 424 lbs./in.
These stiff enough to give me good cornering and weight transfer to plant the *** of the car? I'm looking for good weight transfer at the 1/4 mile track and stiff enough to corner nicely in the twistys.
If these wont do the job then what is an all around good spring for dual purpose?
Thanks, Chas
Old Feb 10, 2010 | 08:12 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: These stiff enough?
nope. they are front springs. the rear springs neck down at the bottom where they fit on the rear. only springs that fit our cars are stock replacement moog 5665s. they have a 107lb rate and will make your car sit abou 1/2" higher than it was when it came out of the assembly plant.
your car even if it had 1000lb front springs would never need more than 175-225lb rear springs and that would be for autoX racing. the only lowering spring that has a better rate than stock is the Eibach prokit, 1" lower with 100-160lb progressive rate. you dnt have any idea what your doing with the suspension if u pick out those springs and think they will fit the rear.
your only options are moog 5665s, custom springs, or pre made kits from summit, ST, eibach, intrax, hotchkins, and BMR.
Old Feb 10, 2010 | 08:14 PM
1988-305-tbi's Avatar
stock iroc fronts are around 550 so that would be a little too soft for the twistys, why are you planning on buying 2 sets of theese, not for the rear i hope....
Old Feb 10, 2010 | 09:26 PM
chas0218's Avatar
Car: 86' IROC
Engine: 388
Sorry i didnt read what i typed i meant to say "I'm buying 2 sets, will these replace my current springs." I'm not buying 2 sets of those springs im buying 2 sets in general 1 front and 1 rear, sorry for the confusion.
Are variable rate springs good for drag and twistys?
I have a set of shocks I already purchased but i just need a set of springs that are almost a dual purpose. I need a low spring rate for the front for it to raise and plant the rear tires for weigth transfer but i want to be able to hug a nice set of S turns without feeling "loose."
Old Feb 12, 2010 | 10:36 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
drag setup and cornering setups are too different to get the perfect combination for both. You can make it ok at both but not spectacular.
Old Feb 15, 2010 | 10:44 AM
chas0218's Avatar
Car: 86' IROC
Engine: 388
What would be a good spring rate for drag racing then? Its mostly a street car but i want descent weight transfer so i can hook good.
Thanks, Chas
customblackbird
Aug 15, 2021 10:16 PM
gord327
Sep 29, 2015 10:18 PM
ChevyLuva3
Feb 1, 2002 01:57 PM
GTA88
Sep 9, 2001 02:37 PM
