lowering springs
Old Feb 18, 2010 | 08:11 PM
tyler86z28's Avatar
Car: 1986 Camaro Z28
Engine: 355 4 bolt 4bbl
Transmission: T-5 manual
Axle/Gears: 3.73 posi.
lowering springs
I just lowered my 86 z28 using Dropzone 1-7/8 drop springs. And now I only got like 3" ground clearance on the front bumper and the rear is higher. Could it be that my engine is heavier (all iron 350 4bolt) or could the springs be designed for a v6 car? Bought off Ebay for $100. Thanks!
Old Feb 18, 2010 | 09:25 PM
MADMAXGTA's Avatar
Car: 89 TTA
Re: lowering springs
Sounds possible,Id get yourself a Eibach pro kit.
Old Feb 19, 2010 | 11:58 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Give them some time - the rears will compress some. If you had sagging original rear springs, the drop springs might actually hold the car higher than the sagging old springs. But if you got the isolators put in correctly, they will drop some more in time. The first 5-10 days after I installed my Eibachs, the car was higher than before, but it settled with driving and usage.
Old Feb 20, 2010 | 12:27 AM
1988-305-tbi's Avatar
the springs will settle a 1/2" or so in the next 100 miles, if the rear still sits too high pull the isolaters and do the heater hose mode that will give you another 1/2-3/4" drop
Bubbajones_ya
Jul 6, 2024 08:32 PM
Lanz06
Sep 14, 2015 07:16 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
