Couple Fbody suspension questions
Old Feb 24, 2010 | 09:39 PM
Elite v1's Avatar
I am in the market for a 3rd gen Iroc 87-90 5 speed TPI.
ANYWAY, this pertains to Fbodies specifically, Im used to modding suspensions and am aware of the concepts/basics/general knowledge rules of the road.
1. I was reading one of the stickies, and from what I understood, is that lowering an Fbody, actually puts the control arms at an upward angle towards the wheel?
Are the control arms parallel to the road from the factory? Being this is the best gauge when lowering your car, to keep the arms parallel.
2. Are the stock springs progressive or linear, if they are progressive, Ill just get adjustable shocks with stock springs, to keep the control arms level, or if they are linear, ill get progressive coilovers and keep them at stock ride height.
3. as far as aftermarket companies, which websites have been the most reliable/decent priced? I come from a cavalier, so we have our share of untrusted companies.
Old Feb 24, 2010 | 09:53 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Couple Fbody suspension questions
yes they can
i believe the bottom of the spring pocket is level at the original ride height, but im not 100% on that
linear, coil-overs are not the best thing going for the 3rd gen
UMI performance, Spohn, BMR, that covers most the hard parts. There are others, hotpart for strut mounts, undalanced engineering, global west, racecraft. Skip edelbrock suspension parts and most of hotchkis parts, all grossly overpriced.
Ground control makes a weight jack setup, whick is pretty nice.
Old Feb 24, 2010 | 09:59 PM
Elite v1's Avatar
Originally Posted by //<86TA>\\
yes they can
Why are coilovers not good, I was just reading through a thread on here talking about springs, and I saw that they limit the front tire size, dunno how or why, but what else is wrong with them?
also, from what I understood in the thread, the eibach pro kits are linear in the front and progressive in the back? thats odd.
Mostly I would be looking for a setup that keeps the control arms parallel to the ground, and since these cars are already fairly low profiled, and considering road conditions in my area, I dont think I would want to go any much lower than MAYBE .75-1 inch
Old Feb 25, 2010 | 12:31 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Coilovers limit front tire size because the strut is already near the tire, and putting the springs on them makes them about 1.25" closer. Also, the top of the spring has to mount to the body, and the bottom sits on the strut, which bolts to the spindle, which turns when you turn the wheels, so there has to be a bearing on each end of the spring.
Not a problem if you just want to go in a straight line.
Front linear/rear progressive is a common setup.
If you want to lower the car and keep the A-arms level or the ball-joint end lower, racecraft makes 2" drop spindles. Or you can get ball-joints with extended studs.
Old Feb 27, 2010 | 12:01 PM
AM91Camaro_RS's Avatar
Car: 91 Camaro
Engine: 3.1...not hardly stock
Transmission: 700r4....not stock either
I believe he's refering to the rear lca which should be level. for that, there are lower control arm relocation brackets (LCARBs). The front control arm should be slightly angled down on the tire side. but, yes extended ball joints will get you about .5" lower in the front. the drop spindles are a nice option if you have some cash to throw around.
Frozer!!!
Jan 19, 2024 04:55 PM
cam-mike
Aug 24, 2015 07:23 AM
redmaroz
Aug 16, 2015 11:40 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
