sourcing roll bar
Old Feb 27, 2010 | 02:55 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
sourcing roll bar
first off, sorry if this is the wrong forum but chassis is the only thing i could think of. Does anybody know of a company the sells the rolls bars they put in b4c's for 91-92? I have one with the holes in my interior trim from the bar but no bar. I was going to just steal the trim pieces from my donor car but I would rather have a roll bar in their anyways. If nobody has any ideas maybe you could point me towards a good bolt in 2-4 point set up with the same mounting points used. The bar should look like this.
forgot whose pic that was but I hope you don't mind me referencing it.(found in a thread from 04)
Last edited by darkhorse91; Feb 27, 2010 at 02:56 AM. Reason: sloppy posting late at night
Old Mar 6, 2010 | 02:13 AM
chrisblazzer89's Avatar
Car: 1986 Camaro
Engine: 350 v8
Axle/Gears: 10 bolt,disks, 3.23 posi rear
Re: sourcing roll bar
I dont think that is a good place to bolt/weld the rear bars on the car it should be more towards the rear center of the car.
just my 2 cents
Old Mar 6, 2010 | 07:30 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
What a worthless looking roll bar. What's it good for? It doesn't give any position to mount a 5 point harness and it offers zero rollover protection. The main purpose of a roll bar is to protect the driver. That design does nothing.
If you feel you need a roll bar, do it right and forget about allowing any kind of access to the back seat.
Old Mar 6, 2010 | 08:21 PM
Guest
Guest
Posts: n/a
I could obviously tell you and Chrisblazzer did not realise the true routing of the factory roll bar. I lightened the pic for the two of you to see the entire front loop. Its a factory 4 pt bar. Innocent mistake
I have no idea other that checking with S&W roll cages. I would personally mock something up out of ABS drain pipe and angle fittings and then have it converted to DOM by a fab shop.
Old Mar 6, 2010 | 11:21 PM
Car: 1986 Camaro
Engine: 350 v8
I'm talking about the mounting points of the rear support bars the wheel wells are not strong enough to help in any kind of accident
1Aauto
Sponsored Vendors
Feb 8, 2017 03:09 PM
Lanz06
Sep 14, 2015 07:16 PM
Fronzizzle
Sep 8, 2015 12:10 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
