dropped with springs yet sits high up front
Old Mar 11, 2010 | 09:47 PM
blue_thunder91's Avatar
Car: 1991 Camaro Z28
I just installed hotckis lowering springs all around with kyb gr-2 shocks and struts, and the rear did indeed drop about an inch. The front though seems like it didnt drop at all. Does it take time for the springs to "break in"? Any ideas on what could be causing this?
Old Mar 11, 2010 | 09:50 PM
Stephen's Avatar
Car: 87 GTA
Re: dropped with springs yet sits high up front
Have you driven the car any? At least rolled it 50 feet? The fronts suspension has to roll to re-settle in place.
Move the car & get back to us on the results.
Old Mar 11, 2010 | 09:56 PM
Springs have been installed for about two weeks now and car has been rolled in and out of shop while i have been rebuilding tranny. Finally installed tranny today and drove car for a good couple of miles and it didn't seem to make much of a difference. The rear seems to be nicely dropped but its just up front that seems a bit high. Not sure if i missed something during install
Old Mar 11, 2010 | 10:02 PM
Stephen's Avatar
Car: 87 GTA
Check to see if your front springs are indexed correctly. The a-arm has a "notched"/not flat place where the springs set. If they are not indexed (turned) correctly in the a-arm, the car will sit high, because the springs are not sitting correctly (low enough).
Old Mar 11, 2010 | 10:06 PM
I was wondering about that too. I will try that tomorrow morning and get back to you all with feedback, and hopefully some pics
Old Mar 12, 2010 | 06:21 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
There are two drain holes in the a-arm. The end of the spring should sit between the two so that one is covered. The holes can be seen in the following link, post #5:
https://www.thirdgen.org/forums/susp...nsion-how.html
JamesC
Old Mar 23, 2010 | 09:36 PM
Okay so finally got the car back in the shop and springs were not seated correctly! Got them seated correctly and car is now looking good, dropped nicely! Will try to get some pics up soon. Thanks
customblackbird
Aug 15, 2021 10:16 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
