Springs- do they just get weak over time?
Old Sep 11, 2000 | 11:47 AM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
Ahhhh well its good to be back, back down to business-
My rear springs seem extremely soft. i have abig tme with bottoming out, although the ride hieght is stock, not low at all, and i seem to bottom out all the time. I have NEW shocks in the back. reason i ask is cuz i noticed where i bottomed out last- the lca mount on the drives side.. i have a set of ws6 springs inmy basement, and i eventiually plan on lowering the car, but what should i adress here? the springs gone soft, but not effecting ride hieght? doent make sense....
Steve
88 Firebird Formula- deseased 2/9/99- 305 TPI, SLP 3 inch exhaust, SLP Intake runners, SLP cam, 3.45 BW disc brake posi, WS6, NOS, and all that good stuff, 13.~ sec 1/4 mile- hit by what else!?!? a FORD EXPLORER!!!!!!
86 Firebird, LG4, t-tops, slp 3 inch exhaust, catco cat, and a bunch of new/replaced stuff, open element, soon to come, 2 inch cowl hood, 3.42 posi disc rear from a 4th gen, and hopefully a 6 speed!
My Webpage- Battle of the birds, My own Thirdgen Page, still under construction, http://www.geocities.com/soares711/index.htm
Old Sep 11, 2000 | 08:51 PM
Jester's Avatar
IF your springs had a problem you would definatly have it show up in ride hieght. sounds like you problemn is more worn out shocks/struts.
Old Sep 11, 2000 | 09:10 PM
fb305svs's Avatar
new shocks in the back- are the springs just that soft?
it doesnt make sence to me either jester that the ride hieght would be fine, but yet it bottoms out a lot
Steve
Old Sep 11, 2000 | 09:51 PM
Tom Keliher's Avatar
What brand of shock did you install in the rear? Is it pure hydraulic; or low gas or high gas pressure?
Do you have stock aluminum wheels, or big honkin' steel chromies with 275/50 meats on there adding unsprung weight?
Do you have 100 pounds of stereo gear in the hatch?
We need more info to help you out.
FORMULA 350 TK
Southern California 3rd Generation F-Body Organization©
Old Sep 11, 2000 | 09:54 PM
fb305svs's Avatar
got a small 10 inch sub with a small amp, stock wheels and tires (235/60 r15) and gabriel Sport shocks(the stiffer ones) high gas i think.
Steve
Old Sep 12, 2000 | 06:55 PM
OK, it doesn't sound like you are carrying any real extra weight back there. Well, maybe new springs are worth a try. I do know however, since I had them myself, that Gabriel shocks/struts are on the soft side.
FORMULA 350 TK
Street Lethal
Apr 30, 2019 12:14 PM
E Rod
Aug 28, 2015 05:17 AM
justin57
Aug 20, 2015 07:05 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
