Fast Gear Box? HELP!
Old Mar 13, 2010 | 07:08 AM
ProtoMaster22's Avatar
Car: 92 Camaro RS
Engine: Vortec TPI 412
Axle/Gears: BorgWarner 327 Limited Slip
I have a 92 camaro RS and my gear box went out .now I've herd that there is a quick ratio gear box is this true? and how do you know if you have the soft suspension or not they ask when i go to order a new gear box any help would be great Thanks>
Old Mar 13, 2010 | 07:18 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Fast Gear Box? HELP!
you may find the following interesting:
https://www.thirdgen.org/forums/hist...-steering.html
JamesC
Old Mar 14, 2010 | 10:27 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Axle/Gears: 3.23 posi
I'm pretty sure the one you have is quick ratio. I found out my 91 RS did after I purchased two of them. I've rebuilt two of these things and it isn't hard. The rebuild kits are around $35 and contain the seals and bearings needed to rebuild it. There is a very good thread here on the whole process. I'll see if I can post up the link. It something like "steering box rebuild rag joint and pit arm...."
Old Mar 14, 2010 | 10:32 AM
jb3829's Avatar
Car: 1991 RS
Engine: 383 stroker
Here ya go
https://www.thirdgen.org/forums/susp...build-rag.html
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Fast355
Dec 2, 2016 06:33 PM
zayne0
Aug 24, 2015 07:22 PM
Dialed_In
Aug 20, 2015 01:45 PM
