Drag Racing without a rear sway bar.
Old Sep 14, 2000 | 03:38 PM
Guido's Avatar
Car: 2000 Trans Am
Does it matter or not? I have not put mine back on yet after I installed my Ford 9" though I have the parts. Does it make that much a difference with it installed vs. not installed?
I managed to cut a 1.93 60' on a set of nittos on my blown 355. no LCA brackets.
-86 IROC
Vortech stuffed EFI 406 in progress
-=ICON Motorsports=-
Old Sep 14, 2000 | 08:48 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You don't really need it but it really helps. Anything that helps keep both tires planted on the ground will help. The sway bar will prevent the right wheel from lifting. You can increase traction even more by using air bags in the springs.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Old Sep 15, 2000 | 08:18 AM
SteveSpohn's Avatar
Keep the front sway bar off, and run the biggest rear sway bar you can get on there. The rear sway bar really helps control body roll on launch.
Steve
Spohn Performance, Inc. - F-Body Suspension Specialists
Old Sep 15, 2000 | 12:13 PM
Matt98SS's Avatar
yeah believe me I seen a car with no rear sway bar on with a 9" as well....the car looked like it wanted to pull one of the rear wheels too! lol....
get the biggest one (there are some honking big ones for thirdgens IRS sells) like Steve said or opt for the Wolfe Racecraft or Comp Engineering makes one similar to Wolfe for cheaper but just needs to be modded to work
AussiePr0nCar
Mar 6, 2020 04:04 PM
Street Lethal
Apr 30, 2019 12:14 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Warlocksirix
Sep 3, 2015 12:26 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
