Handling, what mod to do next? HELP
Old Sep 15, 2000 | 07:58 PM
JDMZ28's Avatar
Car: 2KGTP
Engine: supercharged 3800 L67
Transmission: 4T65E
Axle/Gears: 2.93
My car handles great with the upgrades I've done but it still doesn't grab as much as it should in the front end. I was hoping you guys could help me decide on what to get next. I have an 86' Z28 with this chassis setup:
- 245/50-15" Euro T/A's H rated
- Subframe connectors
- Eibach springs
- Monroe Sensacraps(I think they are blown)
- Reinforced rear LCA's w/poly bushings
- Spohn Adjustable panhard rod (getting)
- Stock 1.33" front sway bar w/poly endlinks
- Stock .90" rear sway bar w/poly endlinks
What should I do next? Struts? Swaybars? 275/40-17's? Thanks.
P.S. Do Koni's make a noticeable difference in handling over stock?
1986 CAMARO Z28 -> 150,000 original miles, 89' vette 350 block, Holley 650 DP, Weiand intake, 1.6 rockers, 1 5/8" headers, no cat, 2 1/2" Flowmaster catback, Mallory coil, March pulleys, T5 with 3.35 1st gear, 90% Centerforce clutch, 3.73 posi, Eibach 1" drop springs, reinforced LCA's w/bushings, Subframes connectors, polyurethane swaybar bushings/endlinks, 2 12" Sound Streams, 2 Infinity 6X9's, 2 Pioneer 6X9's, 800 watt Lanzar Vibe amp. ET 13.22@ 106.4MPH Next mods-> Adjustable panhard rod, LCA lowering brackets, homemade ram air, B&M shifter.
Old Sep 15, 2000 | 09:16 PM
Philip92-z28's Avatar
I would do shocks and struts first . konis will be 10 times better than stock , I have Bilstein on my car and love them . I would do this before going to 275-40-17 .
92 Z/28 122,000+ miles
4-wheel disk brakes 3.23 posi rear end
-Airfoil-
Hotchkis= LCA, Panhard Rod, 1inch Lowering Springs, Tie Rod Sleeves, Strut Tower Brace-
Bilstein Shocks, Struts- Moog- Poly Bushing- Wonder Bar-
AGR Steering Box , Pump-
Wheels Simmons OM-17 ,17x9.5
Tires-Firestone 275x40x17 SZ50 EP more to come
1/4 time
14.202 @ 96.20, 60' 2.008
[This message has been edited by Philip92-z28 (edited September 15, 2000).]
Old Sep 15, 2000 | 09:25 PM
Chad91Rs's Avatar
I'd get new shocks and struts next for sure.
They are too important to pass on and will make a world of difference if yours are worn.
Two things that will help your front end are the wonder bar from Global West and a strut tower brace like the one from Edelbrock.
Old Sep 15, 2000 | 10:14 PM
scooter's Avatar
Car: 92 Firebird
Engine: 4.8 LR4
Axle/Gears: 3.45 9 Bolt
I dont know much about the tires you have on the front but unless they are really soft you arent going to get the handling you want. Tires are the LAST place you should skimp. My feeling is tires make or break a car handling wise. My friend has yoko avs sports. They are a decent tire to start with, but for Really good performance you should run yoko a032r's. Damn they are soft. On the back you could use the same but they wont last long.
James
If the women don't find you handsome they should at least find you handy. Red Green
Old Sep 18, 2000 | 02:55 PM
TOD's Avatar
TOD
Right on, Scooter! If you are looking for some good, sticky rubber on a budget, the Tire Rack has Bridgestone Potenza RE71's for $88. That is for the 245/50zr16's. The tread wear on them is 140, and you can stick your thumbnail in 'em and leave a mark.
New (to me) 87 Formula 350. Edelbrock TES, Flowmaster, airfoil, K&N in modified airbox, March underdrive pullies, still slow....for now.
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
Numbah-1
Oct 2, 2015 08:27 AM
ndndndnd
Sep 28, 2015 08:00 AM
