suspension problems? All over the road....
At this point, my suspension is all stock. I have a 91 GTA with 102,000 miles. My problem is that the car tends to pull, rather violently, side to side. This problem is especially bad when I am driving at high speeds, in the middle of a turn, or at it's worst if the road is a little bumpy.
I believe the problem to be the weak LCAs and panhard bar that I have on my car now. Has anyone else out there had similiar problems? Does changing the LCAs and panhard bar help out in the control of the car?
Car: 1991 Formula Firebird
Engine: 2001 LS1 Modded
Transmission: 2001 4L60E Yank SS3600 TC
What's your tire wear like? If you see cupping or uneven wear the problem could lie in the front end. Do you notice a change in the pull on breaking. It's possible one of the front calipers can be hanging up. Your best bet is to go and get it aligned. There they will inspect all of the front end parts for wear. At 112k I am sure you may need to replace a few things.
