Is no chassis flex bad?
Old Sep 20, 2000 | 08:59 AM
UVA3rdGen's Avatar
How stiff is to stiff? Or is a stiffer chassis always going to respond better? I am probibly neglected some major fundementals of suspension and chassis engenering, but for some simplesity if anyone could shed some light on our cars in particular it would be greatly appriciated.
Old Sep 20, 2000 | 09:34 AM
SteveSpohn's Avatar
It depends on the application. For drag racing you want the chassis as stiff as possible, flex is bad.
For corner carving, you want some flex in the chassis.
With that said, it's impossible to get an F-Body to be totally solid, there will always be chassis flex, even with the best SFCs on the car. Keeping it to a minimum is why we install well designed SFCs.
Steve
Spohn Performance: F-Body Chassis/Suspension Specialists
Old Sep 20, 2000 | 01:41 PM
UVA3rdGen's Avatar
speaking of which steve, when are you going to start producing your SFC? I am holding of on installing the ones i currently purchased to see what you will be building.
Old Sep 22, 2000 | 08:58 AM
Mikey G's Avatar
Car: 85 Trans Am
Engine: LB9
I do not agree with Steve on one point of his chassis flex comment. The less flex the better whether its road or drag racing. Of course it is impossible to rid yourself completely but this is a case of less is more. Chassis flex is somewhat unpredictable and difficult to tune out. If we were comparing lap times, you would have a much easier time setting up a more rigid car to run faster.
The only problems with being to stiff are for safety reasons. If the car is to stiff to absorb some of the crash energy, the drivers body will absorb more. I know of 6 NASCAR Modified drivers who broke their necks and died before the chassis builders started using smaller frame components that were engineered to absorb impact.
Old Sep 22, 2000 | 11:41 AM
SteveSpohn's Avatar
A solid chassis will allow tire lift on hard cornering. I'm not talking oval track, I was talking road racing. When the inside front tire is off the ground, that is not what you want, you want all 4 tires on the ground.
With that said, like I noted, you'll never get a uni-body car that extremely stiff.
I do agree that chassis flex is unpredictable and difficult to tune. I think a very well designed and installed SFC system keeps the flex consistent, and therefore tunable.
Hopefully others will join in here and provide some real world input. I know there are alot of corner carvers on here! These discussions are good, and very educational for all. I learn something every day.
Steve
Old Sep 25, 2000 | 11:16 PM
Tom Keliher's Avatar
Yup, I have read in a magazine article or maybe on of my books that the "engineers" designed our cars to have flex in them and that when the flex is taken out through the use of subframe connectors/stiffer chassis parts it is supposed to be a bad thing.
HOGWASH!!
I have experienced both sides of the envelope, and the stiffer I get my car over the years with chassis improvements, the better it handles; the better it rides; the better it accelerates; the better it brakes.
I'm no engineer, just an end user, but I speak from direct experience as a "canyon carver". True road racers or auto-xer's may take issue with me, but for a street driven and canyon raced car, stiffer is where it's at!
FORMULA 350 TK
Southern California 3rd Generation F-Body OrganizationŠ
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
New2Chevy
Sep 28, 2015 12:35 AM
Chad Speier
Sep 24, 2015 12:32 PM
buckshot63
Sep 10, 2015 09:15 AM
SG91camaro
Sep 5, 2015 10:27 PM
