Glass Vs. Lexan T-Tops
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
I have the Lexan T-tops on my 89 Formula. I want to put glass ones on though. Is it just the Lexan tops that have a 5/8 (roughly)security pin in them? The glass ones seem to have a 3/8 (roughly) pin, what year have the larger pin?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I swapped my 87 glass tops for some 89 lexan ones. The pins were the same size. I don't know what the size was. Someone on the drag forum is looking for some lexan ones.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
[This message has been edited by Stephen 87 IROC (edited September 28, 2000).]
Best 60 foot: 1.662
you just gotta be careful about what year you get the glass ones from...just make sure that they're from a thirdgen after 87 or so because the earlier types have a different setup, so it is a quick swap if you get the right ones...
I wish I could get some lexan ones for my '82, but I have to grab the whole mechanism to get them to fit.
82 Z28
355 carb'd, Edelbrock Performer RPM package (minus heads), Hooker Super Comps, Mufflex 4" offroad y-pipe, 700r4 with B&M shiftkit, '85 IROC 10 bolt rear with Richmond 4.10's & Auburn posi unit, Lakewood 50/50 drag shocks. Shooting for 3000lbs w/ driver.
The car's website (New design in progress...very cool look)
(383/TH350 buildup this winter)
AIM: Unitedhope
ICQ: 77979548
82 Z28
AIM: Unitedhope
ICQ: 77979548
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
Thirdgen89GTA
Nov 26, 2015 11:04 PM
