New Suspention idea...
I recently changed rears..and lost with it my LCA lowering brackets I welded the f%ck out of. I got to thinking about making a new set for the new rear, and a thought occured.
Why not follow the same principle with a new torque arm? What would happen if I made a new arm, and a crossmember/driveshaft loop to mount it on, but I made the rear mounting point a couple inches lower?
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The torque arm works like a 4' long ladder bar. You don't mount ladder bars with the rear lower. You still need to use it to adjust the pinion angle. The lower control arms are more like the bottom rods of a 4 link suspension. Because of the wierd way a third gen suspension is designed, lowering the rear of the LCA will move the instant center of the car more than the torque arm will. It's all on how the diff wants to rotate and transfer force on the body. The LCA's push forward and the torque arm pushes up.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
CR-SuperChevy
Jan 29, 2002 08:09 PM
Xenodrgn
Nov 24, 2001 07:45 PM
Christos
May 12, 2001 07:32 PM
