where to begin
Old Mar 21, 2010 | 10:14 PM
iroc stangs's Avatar
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
where to begin
Ok im going first be working on the suspension for my camaro and my goal for the camaro is to have it be able to take the corners confintly but i still want the ride to be comfortable as this will be a daily driver and going on long trips. But i dont wanna be spending a boat load of money for suspension parts but i dont want be buying cheap stuff and get junk. But i have no idea where to begin and I would like to start off on easier things that doesnt require to much know-how. So where should i begin on this quest for a comfortable peformer? Thank you.
Old Mar 22, 2010 | 06:51 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: where to begin
Originally Posted by iroc stangs
Ok im going first be working on the suspension for my camaro and my goal for the camaro is to have it be able to take the corners confintly but i still want the ride to be comfortable as this will be a daily driver and going on long trips. But i dont wanna be spending a boat load of money for suspension parts but i dont want be buying cheap stuff and get junk. But i have no idea where to begin. So where should i begin on this quest for a comfortable peformer.
With the exception of the sway bar bushings and end links, replace all rubber with rubber.
JamesC
Old Mar 22, 2010 | 11:08 AM
Engine: 305TPI
Re: where to begin
JamesC
sorry i dont know much about suspension. So is that like ball joints, tie rods, and what else? Are these typicaly easy to replace? Thanks.
Old Mar 22, 2010 | 11:13 AM
JamesC's Avatar
Re: where to begin
Comfort, do the above, along with some new struts/shock and tires. Handling/steering, check the following link, which will provide some ideas of where to start:
http://www.spohn.net/shop/1982-1992-...GM-F-Body.html
JamesC
Old Mar 22, 2010 | 12:01 PM
Engine: 305TPI
Re: where to begin
JamesC
thank you. and should i expect any better cornering feel to the car and should all the rubber/shocks/struts at the same time? and should i look into springs?
ZZ3Astro
Aug 13, 2019 12:57 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
starliner
Feb 9, 2016 08:18 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
Marc Brown
Sep 28, 2015 01:40 PM
