want to redo front end...what original components should i keep?
Old Oct 3, 2000 | 09:16 PM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
i want to rebuild most of my front end suspension. i know i need tie rods and ball joints, but i am sure the rest of the front end could use a little freshening. my question is this...what parts should i upgrade to aftermarket, and what parts should i just stick with the stock (new of course) stuff?
as far as i know, stock tie rods are fine, but i need aftermarket adjusting sleeves. right?
also, the local suspension shop reccomended MOOG parts if i wanted to go for a heavier duty suspension.
i already plan on poly bushings, but what else should i upgrade? everyone is talking about this infamous "wonderbar", whats the deal with that thing?
my usage is pretty normal driving with a little crazy stuff here and there...no autocrossing or anything.
any and all input would be greatly appreciated. thanks
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Transcooler
Brian's 1991 RS
Central NY F-Body Association
Old Oct 4, 2000 | 01:25 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Yes, get Moog parts. Id get inner and outer tie rods, idler arm, centerlink and ball joints. Unless your tie rod adjusting sleeves are messed up, just reuse them.
The wonder bar ties the left and right frame rails together. It bolts in where the sway bar bolts are and is a worthwhile mod.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
[This message has been edited by Justins86bird (edited October 03, 2000).]
Vintageracer
Jan 10, 2020 05:33 PM
69 Six Pack
Oct 5, 2015 07:51 PM
Polo Z03
Sep 10, 2015 06:43 PM
kyleb24
Aug 15, 2015 08:24 AM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
