Grease for Poly bushings
Old Oct 9, 2000 | 05:32 PM
Ron Mullins's Avatar
I'm using Spohn LCA's and Panhard rod. It says to use a synthetic silicon based water proof marine grade grease. Would any synthetic grease work. Like Valvoline Synpower Synthetic Grease?
Thanks in advance.
91 Formula WS6
Home Made Ram Air,K&N Air Filter,Air Foil,
Ported Plenum,Underdrive Crank Pulley, Crane AFPR, Edelbrock High Flow TPI Runers, Holley 19lb Fuel Injectors, SLP Headers, SLP Y Pipe & Complete SLP 3" Exhaust and Muffler, High Flow Cat, Mobil 1 Oil, Hotchkis STB, Spohn LCA's and Panhard Bar and other polyurethane goodies.
Http://www.geocities.com/91formula
Add your 91 F-Body to my 91 F-body's Links page, or be added to my F-Body Links Page.
Old Oct 11, 2000 | 11:12 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
That's what I am using. I haven't tried to find the marine grade grease, but it is probably stickier so less prone to washing out. I have converted most of my suspension points to zerk fittings so I can re-lube them.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
