traction?
Old Oct 10, 2000 | 12:09 AM
danzig27's Avatar
Car: 91 Camaro Z28
Transmission: TKO 600
Axle/Gears: 10 bolt 3.23
traction?
I've got some traction problems and not alot of money, so i was wondering what would be the best bang for the buck. And also in the future what would be a good setup?
Wally
86 IROC with the "unknown motor"
84 Berlinetta
Old Oct 10, 2000 | 01:17 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Nothing beats a good set of tires. If you dont already have good tires, then i suggest you start there. All the suspension mods in the world wont help if you have bad tires. Once you get good tires, things like LCAs and lowering brackets will help traction alot.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Oct 11, 2000 | 11:43 AM
lonsal's Avatar
Axle/Gears: 3.45, 3.27, 3.27
Check the angle of the rear lower control arma. If your car has been lowered or the springs have sagged they may be higher in the rear than in the front. LCA relocation brackets are available from many sources that weld on and allow you to lower the rear mounting point to improve traction. Also good shocks will help keep everything planted to the ground. Good luck, Lon.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
Numbah-1
Sep 12, 2015 08:57 PM
dbrochard
Sep 7, 2015 09:41 AM
IROC Z Z28
Aftermarket Product Review
Sep 9, 2001 11:06 PM
