E-brake not workin Pleeze help!!! 3 days till inspection :O(
Old Oct 7, 2000 | 05:25 PM
eddie89TA's Avatar
Car: 89GTA
Engine: 355TPI Edelbrock heads, base. SLP r
Transmission: TCI streetfighter 700r4
Axle/Gears: B/W3:27
i have an 89GTA with disc rear brakes (borg warner 3.27 posi).. i failed inspection today. my E-brake will not hold the car in drive at idle. i tightened the cable adjuster (above the drive shaft) and i replaced the brake pads, i think i *ucked up cause i used a c-clamp.can i still get the e-brake to work? but b4 i replaced the pads, it didint grab! i also adjusted a small allen screw on the caliper that was mentioned in the manual, but still will not hold the car at idle! what am i missing what do u suggest? i have 3 days till my temps run out thank for the info
Old Oct 8, 2000 | 01:47 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
i have an "82Z which has an 89GTA disc rear w/BW 3.27. and i have the same problem. i also did the c clamp thing. i have two tiny springs on each rear caliper that do not appear to be hooked to anything. i think i also need more advice than "the book" can provide. thanx,ANDYZ28
Old Oct 8, 2000 | 06:02 PM
IRACE87's Avatar
Car: 1987 IROC-Z
Engine: 383 HSR, AFR 190
I have the same problem and could't find a way to make it works.Even my mechanic failed in is attemp to make it works.
1987 IROC w/T56 and a 383 TPI in the works
Old Oct 12, 2000 | 11:24 PM
farm-kid/88camaro's Avatar
take a look at the topic "Anyone who is having rear disc problems..." Theres seems to be alot of us having trouble with this setup. Im ready to give up
AmpleUnicorn88
Brakes
32
Nov 18, 2015 11:02 AM
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
CatmanFS
Sep 19, 2015 09:00 AM
Stroopwafel
Sep 11, 2015 06:38 AM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
